Drift Boat Inner Sheer Issue.
Canoes, Kayaks, Pedal power
Roger9
Re: Drift Boat Inner Sheer Issue.
Post by Roger9 » Wed Nov 13, 2013 9:31 pm
Their only temporary forms. They will be removed after the hull has been turned.
jprice
Post by jprice » Thu Nov 14, 2013 9:17 am
Interesting. I haven't seen one built like this before.
So I guess it's sort of like stitch and glue, but with a hard-chine. Are there any permanent frames in the boat?
Roger9
Post by Roger9 » Thu Nov 14, 2013 10:39 am
Yes once the hull is flipped, there will be support frames added via benches and storage. However it is not a stitch and glue boat; it has as you mentioned a hard frame, which the plywood will be attached to with screws. The plans were designed by Ken Hankinson. After years of talking about beginning a boat project, it has be dream come true to finally start one. The only problem... I cant wait to finish this one so a can start another!
skyday
Post by skyday » Sat Feb 02, 2019 7:32 am
bro
it can run but would be a bit slower and does not harm your lipo at all , but that depend on how big your boat is and also the prop size.
Return to “Human Power”
