Glen-L sneakbox
Guest
Glen-L sneakbox
Post by Guest »
Hi All,
I have rebuilt an A.broadbill with a friend 2 years ago. New transom, 2 new stringers, topside, and haul..... It would have been much easier to start with a pile of wood.
He, my friend, built a Glen-L sneakbox. AKA Barnegat bay sneakbox.
Here Go's, I would love to build a Barnegat Bay Sneakbox. but, I want planing haul, not a displacement haul. How do you go about changing the plans? Or will Glen-L do that for you?
I don't know enough about the plans to ask the right questions.
Cigar
Post by Cigar »
Ps I am Cigar... Don't know what happend....
Barry
Post by Barry »
A sneak box is meant to move easily through the water; sailing being one option. A planing boat does not do this well.
Glen-L does not do custom designs and it is probably more complicated than this, but...
The Sneak Box hull bottom lifts toward the transom (rocker). A planing boat will have more or less horizontal lines from mid point to transom. Note: "more or less".
Also, if the aft lines were straight (though not horizontal) and weight were shifted aft so as to ride on a flat part of the hull, the hull might well plane.
Realize that if you choose to sail or paddle a planing hull, it is a lot more work.
Cigar
Post by Cigar »
Thank you Barry,
Do you know of anyone/company that would redraw the plans? Or is it easy to do myself? I have ZERO time working on plans/blueprints :oops: .
John :)
RonW
Post by RonW »
Hey cigar. check this out.
http://www.glen-l.com/designs/special/dsn-sbxlb.html
Not to argue with barry, but the plans do show a power version, which is probaly a small one. If you want to really fly with a larger engine, check out www.boatdesigns.com and look under duckboats, believe they have some that will flat fly.
Return to “Miscellaneous”
