It is currently Mon May 20, 2013 6:39 pm
PostPosted: Sat Oct 30, 2010 4:19 pm
•DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it.
•WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench at the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh*t!'
•ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
•SKILL SAW: A portable cutting tool used to make studs too short.
•PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
•HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
•VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
•OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
•TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
•HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
•BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
•TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
•PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
•STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
•PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50-cent part.
•HOSE CUTTER: A tool used to make hoses too short.
•HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
•UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as leather seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
•FRIGGIN TOOL: Any handy tool that you grab and throw across the garage while yelling 'FRIGG' at the top of your lungs. It is also, most often, the next tool that you will need.
PostPosted: Sat Oct 30, 2010 4:26 pm
You hit it all on every count!
PostPosted: Sat Oct 30, 2010 4:37 pm
I believe I own most of those tools and I multiple friggin tools
PostPosted: Sat Oct 30, 2010 4:54 pm
Dave,
I'm not allowed to have a DRILL PRESS, a SKILL SAW, or a BAND SAW. :( And they took my OXYACETYLENE TORCH away from me. :shock: I still don't know why. The insurance company paid for the damage to the garage and my hair is slowly growing back. :roll: :wink: :lol:
PostPosted: Sat Oct 30, 2010 5:59 pm
The insurance company actually pays me not to have some tools :!: :wink:
PostPosted: Sat Oct 30, 2010 8:28 pm
That one never gets old.
Ian (aka Iggy)
My Malahini Build
PostPosted: Mon Nov 01, 2010 5:28 am
And some of my own favourite.
* Chisel : a sharp tool generally used for extracting blood from hands foolishly holding the work piece in front of the blade. (albeit in this case I got away with a flesh wound) :oops:
* Socket : Perfectly round on the outside to allow it to roll as far away as possible as it bounces off your foot. Often comes in a set of all the sizes except the one you need (due to afore mentioned rolling)
* Circular saw : tool for removing carbide tips from saw blade as they intersect the metal work-stand at 5600 rpm. This has an optional blade height adjuster which may reduce blade damage.
* JigSaw : tool for cutting through oak and Black & Decker Workbench at the same time. (http://davesboat.blogspot.com/2007/07/f ... rames.html)
PostPosted: Mon Nov 01, 2010 4:15 pm
Not only do table saw projectiles test wall integrity. They also test the integrity of a freshly completed 1/4 inch plywood boat hulls!
KB
PostPosted: Mon Nov 01, 2010 4:53 pm
:lol: shapers do a better job of that I had one throw a piece and stuck it into a wall 20 foot away and 15 foot from the floor :roll: :lol:
14' Mr John-Wild Flower 2
Rod H
PostPosted: Mon Nov 01, 2010 6:55 pm
KB
Kevin - Obviously, you did not look closely at the starboard side of my hull just under the windshield. It was the plywood laminations that prevented the projectile from exiting the port side.
dave
PostPosted: Wed Nov 03, 2010 10:12 pm
Somehow I have managed to do most of my damage to myself/my shop/vehicles/bystanders/windows with a combination of lathes, and surface grinders. All lathes should come with a built-on vet wrap dispenser. It's worse than Wiley coyote with a truck-load of "ACME" crates.
PostPosted: Thu Apr 19, 2012 12:12 am
Maybe this guy should try some Bennett Marine Trim Tabs to get him up on plane...
582029_10150715999918780_268788468779_9410945_901998602_n.jpg [ 28.5 KiB | Viewed 419 times ]
Rod H
PostPosted: Thu Apr 19, 2012 1:51 am
I've just had a few friggin good laughs reading these posts..... :idea: all sooo truuuue :idea: oldies but goldies
SS FATGUY just topped it off :lol: :lol: :lol: Thanks
Tim
Users browsing this forum: Partagas and 4 guests
cron
