It is currently Sat May 25, 2013 11:34 pm
Post new topic Reply to topic  [ 7 posts ]
 Post subject: How to glue plexiglass?
PostPosted: Fri May 21, 2004 9:22 am
I tried to glue my plexiglass windows to the varnished wood. Didn't work at all. The glue I used was Casco marine & tech. Anyone who know what will work
 Post subject:
PostPosted: Fri May 21, 2004 11:04 am
Clear silicone is about the only thing that might do it.
Graham in Shepperton, England
 Post subject:
PostPosted: Sat May 29, 2004 11:46 am
Here is an Idea try auto window sealant? woth a try it is flexable and weatherproof.
 Post subject:
PostPosted: Sat May 29, 2004 1:06 pm
Auto window sealant IS silicone isn't it?
 Post subject:
PostPosted: Mon May 31, 2004 8:02 am
I was thinking the black stuff and id drys alot more flexable. More for weather striping
 Post subject: Kjetil
PostPosted: Mon Sep 20, 2004 11:47 am
I found a glue that did the job. Sikaflex 295 UV. Very expensive. Only one problem. The PLexiglass expanded a lot in the heat from the sun. Resulting in deformed windows and cracked window frames. I have removed everything and am now putting in real glass. (hardened safety glass). Amazingly the glass was cheaper than plexi despite expensive hardening process.
 Post subject:
PostPosted: Mon Sep 20, 2004 11:51 am
I found that too, toughened glass works out much cheaper, as long as you only need flat panels it has to be the best choice, that's what I'll use when I finally get around to making a windscreen.
