Things To Do With Your Building Form
Post by Bill Edmundson » Mon Jun 03, 2013 3:45 pm
I still have more lumber.
darthplywood
Re: Things To Do With Your Building Form
Post by darthplywood » Tue Jun 04, 2013 5:16 am
I turned mine into a workbench (I will post pictures soon)
yet to come...11' Glen-L "Utility"
fergal butler
Post by fergal butler » Tue Jun 04, 2013 5:46 am
Good idea Bill " Things to do with your Building Form" Mine became a mockup of the hull to work out the prop shaft angle and the space between the prop and rudder.
It was also my engine stand for a while and helped with lining up the engine and the clearance of the bell housing and oil pan.
jeffh
Post by jeffh » Tue Jun 04, 2013 7:05 am
Fergal, that's a nice transom shot on the wall. The engine is nice too.
scottinwv
Post by scottinwv » Thu Jun 06, 2013 5:34 pm
I built boxes.
The pine boxes were the build form. Used 2x10s, planed them to around 5/8", got out the dovetail jig, made a cooler and a couple toolboxes for the boat, and a few sea chests for around the house. I planned ahead using the wider lumber, and was careful about screw placement for crossmembers.
Scott
Old aussie
Post by Old aussie » Fri Jun 07, 2013 1:19 am
Wow not many people do dovetails any more ,very nice.......
Peter....
scottinwv
Post by scottinwv » Fri Jun 07, 2013 1:58 pm
Thanks, but I cheated. I used a dovetail jig and router.
Scott
thudpucker
Post by thudpucker » Sat Jun 08, 2013 9:51 am
scottinwv wrote:I built boxes.
Scott
Do you see a great Idea for a childs bedroom Chest of Drawers in this photo?
Make a set of Drawers, in a Spiral setting. The Drawers would all open in different directions with space behind for the 'stuff' the kids throw into a corner.
What a great idea he just created!!! :mrgreen:
Old aussie
Post by Old aussie » Sun Jun 23, 2013 2:28 pm
Cut build form down to make engine stand, will put dummy stringers in to make engine mounts and set up. if I build another boat I will
just weld it back together again....
Peter.....
Return to “Miscellaneous”
