Cooling on mahogany inboard boats
magv12
Post by magv12 »
How do these older inboard wood boats get the water in from the lake in order to do the cooling? Or do they just use a radiator? I'm not familiar with these designs, so excuse me for being ignorant on this. Are there water inlets in the rudder? Or are they somewhere else?
Re: Cooling on mahogany inboard boats
Magv12
There will be a thru-hull pickup that goes to a raw water pump that feed a heat exchanger (wet radiator). This is what cools the engine system. Automotive radiators don't get enough air to work. Also, marine engines are always under load (never coasting). So, they really need a better cooling system.
Nova SS
Post by Nova SS »
that's interesting Bill. I didn't realize that the runabouts used a heat exchanger in them. So the coolant in the motor is not raw water? I know in the hot boats (tornado, rampage, etc) the coolant in the motor is generally raw water normally pre-warmed by cooling the exhaust manifolds first before entering the engine block.
NAMEngJS
Post by NAMEngJS »
Either is possible, the closed system like Bill described or an open system that uses raw water. In a closed system you will have to plumb in an expansion tank to hold excess coolent (water, Naacool, ect.) and the system should be under positive pressure (expansion tank is higher than the rest of the system). The benefit of this is that the engine does not see raw water which is nice if you are in a saltwater environment as it lessens corrosion on internal parts. Also the circulation pump only needs to be sized to overcome the internal pipe friction of the system at the rated flow, it will not have to work to overcome any additional head from the difference in relative heights.
However you will need a second pump to pump the raw water through the heat exchanger (wet Radiator) adding another electrical user (if not engine driven) and the added piping. Both are viable options for the runabouts or any boat provided the builder has adequately prepared for either system.
-Juan Suarez
NAMEngJS is correct. There at two different systems. I prefer the two loop system. Two loop gives more consistent engine temperature. And, if there is a corrosion issue, changing a heat exchanger is easier than the whole engine. I have had both systems. I just feel better with two loops.
"Hot Boats" are trying to save every pound. That is fine.
jenko
Post by jenko »
There is also the simplicity and cost factor between the two types
Return to “Miscellaneous”
