Torpedo X 0.16
Re: Torpedo X 0.16
Post by Jimbob »
Roberta that is looking really great! Looks just like the real thing!
I used to have a radio control boat. It had some sort of sealing foam to keep water out of the hatch area. Water seems to get into r/c boats easily.
Re: Torpedo X 0.16
Thanks, Jim!! It's way easier to work on. Sanding and fairing is a lot easier, too.
Re: Torpedo X 0.16
Post by Jimbob »
Now that I think about it, it also had a clear plastic box with sealing tape for all of the radio stuff. The on/off switch was a push/pull switch mounted in the lid of the box. The boat was a tunnel cat hull with an 11cc outboard motor.
psychobilly
Re: Torpedo X 0.16
Post by psychobilly »
How’s it coming Capt Berta?
Re: Torpedo X 0.16
I've been working on my golf swing in Arizona. Back at the mini Torpedo soon. :lol:
Re: Torpedo X 0.16
You only have 8 1/2 months till you have to ride that thing to Chattanooga! :D :lol: :P
Re: Torpedo X 0.16
Coincidentally, I was just going to post something about a model I am going to be building of my boat.
It will be posted shortly under my build thread.
Re: Torpedo X 0.16
Sounds great, Carl. It's a lot of fun recreating your dream boat in small scale. A lot easier, too.
psychobilly
Re: Torpedo X 0.16
Roberta wrote:I've been working on my golf swing in Arizona. Back at the mini Torpedo soon. :lol:
WHATS wrong? Lil tough to play small ball in the snow? :lol:
Re: Torpedo X 0.16
:lol: :lol: Yup! :lol: :lol: :lol:
Roberta :lol:
Re: Torpedo X 0.16
Congratulations on the flip! Looks great!
Re: Torpedo X 0.16
Busy Spring since being back in Wisconsin after missing much of the winter in Scottsdale. It has been a long winter and as someone said "it's the 95th of January". Between getting ready for a new boat event in Green Bay and organizing things for some new granite counter tops in my kitchen, I have managed to set some time aside for the little Torpedo.
I finished the carlings and attached the upper sub decking. Getting ready to cut the hatch out so I can continue installing the motor and other gear. I have mounted the prop strut and rudder stuffing box. The prop shaft hole was drilled and shaped. I am waiting for a longer shaft log to install in the hole. It has some bushing in it to support the prop shaft. I will install the lower sub decking and cowling later.
My plan is to paint the whole thing white and use a 1/64" iron on wood veneer to trim the decks. That way the white will show through as the caulking and I will then clear finish the deck boards. We'll see.
Roberta :D :D :D :D
Re: Torpedo X 0.16
Post by chugalug »
:D Looks impressive,Roberta.I've not gotten in on the model building yet. just trying to play my one string diddly bows that are homemade from junk. :D
Re: Torpedo X 0.16
Thanks, Chug!! When you get older and more arthritic, building small things is still fun and easier on the bod. :lol:
Re: Torpedo X 0.16
Are you ready for me to get my belt sander out, Yet? :)
Return to “Miscellaneous”
