through-hull drains
through-hull drains
Post by chugalug » Wed May 30, 2018 6:16 pm
I'm thinking about installing a hull drain in my Bo-Jest build.since the lowest point is up in the v-berth area-it would have to be a through hull fitting with a plug.I'm thinking on a bronze fitting and screw in bronze plug(if I can find such a critter)It would be open only while on trailer to drain rain water.Any suggestions?Perhaps a Garboard fitting from Glen-L would work.I'm just a little hesitant about drilling a hole.
Re: through-hull drains
Post by hoodman » Thu May 31, 2018 5:18 am
Bill has stated several times that his garboard drains leak.
Post by chugalug » Thu May 31, 2018 6:15 am
:D maybe some of this on the threaded plug(teflon tape)
was watching video on how to install one in sailboat.guy insists on bronze with bronze plug not copper plug.maybe copper is too soft.
Post by Bill Edmundson » Thu May 31, 2018 6:27 am
I'm planning remove the garboard drain and plug the holes. they seem to act as a one-way valve in. I'd rather rely on the pumps alone than let water in for the pump to get out.
Post by Roberta » Thu May 31, 2018 7:32 am
I agree with Bill. Put a good pump down there and Jack up the trailer tongue or find a good slope to raise the bow up to drain the bilge out the transom drains.
Post by chugalug » Thu May 31, 2018 8:25 am
I didn't install transom drains as hull is shaped like this
Tom Smitherman told me his didn't work
Post by hoodman » Thu May 31, 2018 11:52 am
You could at least pull the transom drains on the boat ramp and it would probably drain there?
Post by chugalug » Thu May 31, 2018 12:04 pm
:D was mainly concerned about sitting on trailer-coarse a cover might work too.or shrink wrap-it's not going back in shed(got another project planned for that)automatic bilge pump should do when its in the water.just wanted to get input about it.thanks everyone :D
Post by Jimbob » Thu May 31, 2018 1:16 pm
I have attached a picture of what might work for you. Classic Chris Craft boats had a drain in the bottom of the boat. The picture is of the thru hull drain like the chis craft boats used. David at Classic Boat Connection said they sell new reproductions that are manufactured by the same foundry that Chris Craft used. He sells them for $58. His phone number is (507) 344-8030. This is a picture of one he has in stock.
Post by chugalug » Thu May 31, 2018 3:18 pm
:D Thanks! saw one -similar concept for 116 bucks at Hamilton marine.Still haven't decided to drill hole yet.I tried to block off vent lines in enclosed bulwarks so rain water might bypass and drain out back vents.Thought a driving rain might enter hull during extended trailer stays and accumulate. :D
tsmitherman
Post by tsmitherman » Thu May 31, 2018 3:32 pm
I can guarantee you that transom drains are useless on the bojest. During construction I had considerable water in the bilge on mine, and I jacked up the trailer as far as it would go, and then drove to the steepest hill I could find - neither method got the water anywhere close to the drain plugs. Not one drop. I used a shop vac.
Just before I sold it, I had water get in again (a grandson with too much free time) so I drilled a hole in the lowest point and the buyer said he’d put in a plug.
36' 1969 Willard Aft-Pilothouse Trawler
Blog: www.genesisboat.blogspot.com
Knot-So-Fast (BoJest) SOLD
Post by hoodman » Thu May 31, 2018 3:45 pm
If you're only doing 8 knots how about a regular brass tube with a rubber plug in the bottom? Bad idea?
Post by chugalug » Thu May 31, 2018 4:06 pm
:D Think I'd be happier with a bronze fitting and plug.made kinda like bilge pump through hull fitting.I'll see if I can find it again.
Rich Coey
Post by Rich Coey » Thu May 31, 2018 4:12 pm
On my Monaco, when it is level the lowest point is about where the drivers feet are. It would be hard to lift the front high enough to drain at the transom. I have a T- handled garboard plug like Jim posted. It is under the front cockpit floorboard on one side of the keel with a limber through the keel to drain the other side. Works great, it is a tapered thread, no leaks.
After I pull the boat out pull the plug and drive home it just takes a couple paper towels to dry it out.
Rich
Post by chugalug » Thu May 31, 2018 4:14 pm
:D This is the one I like.
kinda spendy
Return to “Miscellaneous”
