exhaust hardware question
Colin
Post by Colin »
I have two exhaust manifolds for a small block chev and only one elbow/riser. It is OMC, not sure on the origional application as I bought off ebay for my project boat. I have had little luck locating another used riser and the new ones are terribly costly. My question is this: does anyone know if another riser( ie off a Mercruiser or another plentiful and affordible brand) will fit my OMC manifold?
Dave Grason
Post by Dave Grason »
Colin, where are you located?
Maybe we can peruse the local boneyards and help you find the correct piece that you need................ unless you're on the other side of the pond.
Guest
Post by Guest »
I'm from Canada. Do you have access to boat parts?
I know of 3 companies that cast exhaust parts as replacements for the factory made items.
Barr Marine
Osco
Aqua Power
They make generic replacement parts for cast marine manifolds, thermostat housings and stuff.
Return to “Miscellaneous”
