Deck planking & seams discussions
thudpucker
Re: Deck planking & seams discussions
Post by thudpucker » Sun Apr 11, 2010 1:55 pm
For you guys who have access to Photo Shop, Use the magic wand tool, click on the color you want to change, and only that color will change.
Then you can see what the boat would look like with White, or Blacks strips.
Post by Bill Edmundson » Sun Apr 11, 2010 6:49 pm
I have got a picture of a Lyman with black seams. But, it will be Tuesday before I can get to it.
John K
Post by John K » Mon Apr 12, 2010 5:12 am
Gail,
Thought about one other thing you might want to add. It was suggested to use the spaces used on ceramic tile. I did not do mine this way, but think it would provide a much more uniform spacing. They come in a bunch of widths and would be perfect.
Post by Bill Edmundson » Tue Apr 13, 2010 11:24 am
I thought I had a better picture.
Mark Chadwick
Post by Mark Chadwick » Tue Oct 05, 2010 1:26 pm
On the ideal of different wood - you mean like using holly or sitka spruce for the white?
Have seen patterns on forward deck on a gentleman's racer done that way. Awesome and the joinery was a thing to behold. I'm not sure I would be up to it - but it looked wonderful!
Mark C
alphacat63
Post by alphacat63 » Fri Oct 08, 2010 2:25 pm
Mark Chadwick wrote:On the ideal of different wood - you mean like using holly or sitka spruce for the white?
Mark C
I posted a question similar to this on another forum. I'm building the Malahini. I don't necessarily want to copy this exactly, but the Cris Craft Capri in this photo is kind of the look I'm going for. Based on what I've read thus far, I'm thinking of using thin strips of something like Ash or Holly in the seams. But I also want to do a lighter colored wood down the king-plank and around the cockpit. I've read that these old boats were done that way by bleaching Mahogany, then giving it a very light amber stain. I'd like to go for a look similar to this, but I think it would be too much a pain in the backside to try to bleach lumber. If I can find a wood (again- Ash? Holly?) that's lightly colored and not be prone to any sort of problems, that's what I'm looking for. Any suggestions?
Feckless
Post by Feckless » Sat Aug 27, 2011 8:17 am
Here's a shot of my deck with black seams. Used a 100% silicon black caulking. A trick though is stuff cotton cording in seams before filling with caulk. When caulk starts to show it's age I can easily pull on cording and zip it out of seams in minutes. Also it is supposed to help avoid seam separation.
Black seams
Black seams
It's amazing what one can accomplish when he doesn't know what can't be accomplished.
khundley
Post by khundley » Sat Aug 27, 2011 9:19 am
Mark C
How about maple? Hard, stable (if you don't use figured) not sure of its rot resistance, but its a thought.
Ken Hundley
- Stevie Ray Vaughan
Post by vupilot » Sat Aug 27, 2011 10:20 am
I dont think Ash would look right on a big piece, its very grainy. Holly is pretty expensive so I agree with Hundley, Maple looks like the way to go.
2FunKids
Post by 2FunKids » Sat Jul 07, 2012 2:41 pm
Thanks Gayle, I just posted a question on this topic the other day. Based on my Furniture experience at John Widdicomb Fine Furniture Co, any solid layup will expand and contract and without some type of expansion joint there is the opportunity for cracks. I personally like the Caulk method the best without the varnish over the top. This should allow movement to be absorbed by the elasticity of the joint. If it will easily pull out for restoration as noted on your document that is a good plus. I am also seeing some very nice painted on patterns that are just gorgeous.
Ray
Post by Bill Edmundson » Tue Jan 05, 2016 2:18 pm
I sticking with the 3M4000UV on my decking. But, on the cabin sole and galley top I want to go solid wood. What wood will be the whitest for the seams?
Post by chugalug » Tue Jan 05, 2016 3:01 pm
:D Any chance that wood couldn't be pickled-we used to put this mix on pine cabinets .In qt jar -put 1 cup white enamel paint,1 cup turpentine,and one cup linseed oil.shake up well and using rag to wipe on wood.
Post by gdcarpenter » Tue Jan 05, 2016 6:46 pm
Here's my ZIP decking. Light wood is White Oak, dark accents strips and center board are Bloodwood.
Started with a 2" X 2" X 12' length of white oak, onto one side glued a 1/4" X 2" X 12' strip of the bloodwood.
Ripped the glued up assembly into 3/16" strips, then ran the strips through a planer to take them down to 1/8"
I was left with 'Preassembled' strips that were 2 1/4" wide - 2" white oak & 1/4" blood wood - 1/8" thick.
Post by Bill Edmundson » Tue Jan 05, 2016 7:23 pm
GDC
That is how I plan to do it. Laminate the thin and wide together. Then cut it veneer.
Return to “Miscellaneous”
