Silicon Bronze...Frearson vs. Square Drive
What kind, options, etc.
Re: Silicon Bronze...Frearson vs. Square Drive
Post by Jimbob » Tue Feb 07, 2017 1:45 pm
You might try cc fasteners. I have found that they are cheaper than most.
ToddM
Post by ToddM » Sat May 27, 2017 3:52 pm
Mark-NJ wrote:OK...so I'm sold on the goodness of Silicon Bronze, but I'm absolutely hating the Frearson drive. The "special bit" might have the "right angle"....but to say it's a good fit is a joke. I've torn out enough heads to know it's not "just me". The driver-to-head fit sucks.
Good to know. Thanks.
Post by hoodman » Sat May 27, 2017 5:33 pm
I drove 99% of my frearson screws with a Phillips bit. Having the right sized hole is critical in hardwoods.
Mark-NJ
Post by Mark-NJ » Sat May 27, 2017 6:51 pm
old thread, but since I just got quoted, let me update:
I switched to square-drive very early in the project (over a year ago), and since then the number of torn-out heads can be counted on one hand.
Square drive all the way!
(If anyone offered a sil-bronze in Torx, I'd be in heaven!)
Post by Jimbob » Thu Jul 27, 2017 6:23 am
Square Drive sounds like the way to go. It's too late for me to change now. I already have my supply of Fearson screws, so here is what I do to prevent stripped heads. I countersink and drill with one of those tapered drill bits. Next I drive a common drywall screw that positions the pieces until I am ready to glue. When I glue I remove the drywall screw and drive the bronze screw that has wax (get a toilet wax ring) on the threads slowly with the clutch on my drill set to a low number. Make sure you put a lot of pressure on the screw when driving.
Post by mrintense » Thu Jul 27, 2017 3:01 pm
I used stainless screws and small plywood squares(with a wax paper barrier) to hold the plywood down and after a couple of hours I went out and replaced all of them with silicon bronze screws. Each SB screw was given a dab of thickened epoxy.
