It is currently Mon Jun 17, 2013 10:44 pm
Post new topic Reply to topic  [ 4 posts ]
PostPosted: Mon Nov 29, 2010 4:32 am
is just the bottom fiberglassed or the whole boat then epoxied till glossy ?
how does the wood grain show thru the fiber glass?
thanks brad
bulider in the corn (Monte Carlo)
1964 Chris Craft Restoration : http://boatbuilders.glen-l.com/hot-rod- ... llery=1491
PostPosted: Mon Nov 29, 2010 6:16 am
HI Brad
I glassed the entire boat. I split it up into 5 areas because of the size. 2 sections for the bottom and one for each side and one for the transom. Glen L recommended 4 oz deck cloth and it worked great. This was my first time and it was no problem at all. I appled 4 coats of epoxy and sanded it down to make it smooth. Some folks will tell you that 4 coats is too much and it may be but I sanded so much that it worked out for me. I started with 150 then 180 and then 220 sandpaper. In one section i used 320 and it really looked pretty good. I decided to stay; with the 220 so there will be some "tooth " for the varnish when I varnish it. The Epoxy has no UV protection so you will need to varnish in addition. The wood shows thru the glass like the glass wasnt there. I was skeptical so I did a sample board first. Most people that look at it cant believe it has glass on it.
John Amundsen
Monte Carlo
Winter Haven, FL
PostPosted: Thu Dec 02, 2010 10:49 am
Brad,
Same here. Glass the whole boat. The glass will dissapear when you wet out the cloth with epoxy, like it's see through. You will need to put a few coats on and sand to get the bumpy/mesh-like finish out, but you will be left with a smooth frosted appearance that will turn crystal clear when varnished.
Malahini Build Gallery:
http://picasaweb.google.com/11229065623 ... directlink
PostPosted: Thu Dec 02, 2010 11:11 am
ok, John, you are going to have to come for a visit when I glass my next rig. Glad for ya
Corn builder- I glassed only to the water line.
dave
Video of Midnight in Action
Blog
