I've been waiting for over six weeks to paint my hull. The temperatures simply will not relent. It was 107* Wednesday! This is Wichita, not Death Valley!
In any case, my boat needs painted. The instructions do not give a recomended temp range (strangely), but common sense tells me there must be a limit to what thinning adjustments can compensate for.
So..., I elect to paint my boat--d_mn the temperature. The humidty is low because we are in a drought right now, so that shouldn't be an issue.
I expect that the heat will shorten my pot life (two-part Supermarine Ironsides), so do I thin more to combat that, or less due to the extreme temps? The instructions say to thin to 22-25", Zahn #2. I am familiar with a Zahn cup, but is the 22-25" a time in seconds? The " means inches in these parts. I don't quite get it.
I also can't recal if i activate or thin first...
