orange peel
TOM K
orange peel
Post by TOM K »
what are some different things that can cause orange peel when spraying ?
efanton
Re: orange peel
Post by efanton »
I'm sure I dont have all the causes listed but these are the ones that I have experienced
Generally this happens when the paint has started to dry before it has evened out or adhered to the surface to be painted
Spray gun too far from the surface to be painted
Air pressure too high
paint thinned by wrong thinner
not enough thinner
air temperature in painting areas too cold
"it's never too late to have a happy childhood"
Bill CNC
Re: orange peel
Post by Bill CNC »
Tom,
99% of the time, the paint is to thick which makes one turn up the air pressure.
If your pushing the paint, the pressure is to high. If the paint is thicker than (whole) milk it's more often than not, ... to thick.
efanton,
If the gun is to far away, it will leave the paint dry and powdery/grainy and looking like overspray.
efanton
Re: orange peel
Post by efanton »
Agreed, but on a second coat some would say the result looks like orange peel.
TOM K
Re: orange peel
Post by TOM K »
Im shooting interlux epoxy primekote and it is awful thick. Hit it 220 sandpaper and was going to 2nd coat it or should i sand out all the orange peel 1st ?
Bill CNC
Re: orange peel
Post by Bill CNC »
I'd say more like a painted stucco house.
Bill CNC
Re: orange peel
Post by Bill CNC »
TOM K wrote:Im shooting interlux epoxy primekote and it is awful thick. Hit it 220 sandpaper and was going to 2nd coat it or should i sand out all the orange peel 1st ?
Tom,
Sand it first. It never gets better, only worse. You'll just be adding gasoline to the fire.
EDIT:
Forgot to mention this, ... Read what the can says as far as sand paper grits and reducing the paint and what to reduce it with.
TOM K
Re: orange peel
Post by TOM K »
That is the answer I'm looking for. it never gets onl only worse... So I will go ahead and sand it now. And yes that' remark Soun sounds like.. Is that normal?
Bill CNC
Re: orange peel
Post by Bill CNC »
Tom,
Your last post came out garbled from editing, I do it all the time.
What is the last question about :?: :?: :?: being normal :?: :?: :?:
red
Re: orange peel
Post by red »
what spray gun are you useing hvlp or conventional or lvlp? if its a hvlp it probably has a 1.4 tip which is pretty small for a high build primer so you will need to slow down to lay down more paint and also make sure you have a lot of air pressure atleast 25 to 30 psi to bust up the paint the better you adamize the paint the smoother it will be if it is a conventional gun youll probably just need to up the air pressure
TOM K
Re: orange peel
Post by TOM K »
HVLp with a 1.8 tip. The remark about stucco me laught because that is about what it came out of my gun like. I reduced it down 20 percen,the directions said to reduce it 20 to 25%. just hit it real hard with 220 grit paper on a orbital sander. . Not sure if I want to hit it again or go ahead and spray ? I still can see a slight orange peel. sorry about the jumbo text, was doing it on my smart phone.
TOM K
Re: orange peel
Post by TOM K »
Thanks for all the help and input on the orange peel problem. 2nd coat came out reel nice. A little more reducer and i think the big thing was holding my gun closer. Now I'm ready for my finish coats. I'll post some pic's when I get er done.
Return to “Painting”
