It is currently Mon May 20, 2013 9:12 am
 Post subject: Painting
PostPosted: Mon Jul 19, 2004 10:28 am
When I go to paint certain areas...ie. bottom, bow seam......will I do this before glassing?
 Post subject:
PostPosted: Wed Jul 21, 2004 12:02 pm
No, paint after glassing, otherwise the resin won't penetrate the wood and the glass skin will peel off later on.
Graham in Shepperton, England
 Post subject:
PostPosted: Wed Jul 21, 2004 6:29 pm
Also, do NOT glass over an oil based stain - only water based stains will allow adhesion between the wood and glass. If you've already slipped and put down an oil based stain, simply sand it enough to break the surface. Then you'll have enough adhesion.
