Spray vs brush and roller for topcoat
Shanff
Post by Shanff » Sat Apr 23, 2016 4:18 am
I'm rounding the last corner for the woodwork on my malahini and will be doing my topcoat over silvertip epoxy with system 3 WR-LPU glossy polyurethane. I did this already on the hull before flipping using rollers and brushes and am pleased. I'm considering getting a cheap sprayer from harbor freight since it's a large area including the deck, seats, floor, side walls, with a number of angles and vertical surfaces. I want to best avoid drips and thought it may leave a thinner layer with each coat. I also want to know if I can get the same high gloss finish with a sprayer.
Stephen Hanff
Malahini Build
www.hanff.com/pages/boat.aspx
Dunedin, FL
Ozzieboat
Re: Spray vs brush and roller for topcoat
Post by Ozzieboat » Sat Apr 23, 2016 4:50 pm
Shanff
Although the last coat on my boat was applied by spray in a booth, it was done because of the difficulty I was having with dust. As far as quality of finish, when using a roller and tipped with a foam brush I did not notice any difference. I used International (Interlux) Perfection Plus clear. Just don't roller anymore than about 4-6 square feet before tipping.
Post by Roberta » Sun Apr 24, 2016 5:51 am
You can get a good finish with rolling wr lpu. Make sure to use thin coats, keep a wet edge, and do it when the humidity is high. Wr lpu will run if applied too thick.
Brad Tucker
Post by Brad Tucker » Tue Apr 26, 2016 9:38 am
I shot VC performance with an HF gun and was pleased with the results. I'm planning on doing the same thing using Perfection Plus 2 part poly. I'll let you know if it's a success or a disaster. I already know my brushing skills are terrible!
Brad Tucker
Post by Brad Tucker » Mon May 02, 2016 5:09 pm
Ok.....be sure to thin it right or you'll be sanding a lot.
Brad Tucker
Post by Brad Tucker » Sat May 07, 2016 1:24 pm
I just shot the last 2 of 5 coats with the HF gun. I do have some orange peel but it should sand out. Personally, I did have to thin out. 300ml base, 150 hardener, 100 2316 reducer is what I did. 10% was way too thick for me.
Post by Roberta » Sat May 07, 2016 1:28 pm
With spraying HVLP it is important to have the correct size orifice and don't let the gun get too far away from the work. That will also create orange peel..
