Pettit High Build Varnish 2056
Ronb172
Re: Pettit High Build Varnish 2056
Post by Ronb172 » Sat Jul 02, 2016 7:00 pm
Bill, I have 2 coats of the 1015 on my bout now and it is awesome in my opinion. I pulled to boat off the trailer to finish painting the trailer. but I'll post pic later next week after coat #3. I'm new at this, but I'm seeing no reason to put 6 or 7 coats on whit this varnish. We'll see
Building my third SUP.
Started the Topper build.
Post by Roberta » Sun Jul 03, 2016 5:34 am
The reason for the extra coats is the UV blockers in varnish float to the top of each coat. Some gets sanded off for the next coat. Building up more coats increases the UV blocker so the wood is protected. Some of the high build varnishes that do not require sanding between coats could get by with less.
jamundsen
Post by jamundsen » Sun Jul 03, 2016 6:26 am
Roberta is very correct. You need the extra uv protection.
John Amundsen
Monte Carlo
Lakeland,Fl
Ronb172
Post by Ronb172 » Sun Jul 03, 2016 8:37 am
Good point. I didn't stop to think more coats adds protection.
travis24
Post by travis24 » Mon Aug 01, 2016 2:39 pm
Ronb172
I used 2056 on my Zip. All came out well on my deck & transom.
Travis
Measure Twice, cut Once.
https://waterhogsworks.com/
