Lacquer over Epoxy?
jeff k
Lacquer over Epoxy?
Post by jeff k » Sun Feb 26, 2017 12:55 pm
Hi fellow boat builders. I'm getting very near painting the hull of my Squirt. The paint I want to use is an automotive lacquer. I'm going with an old school large metallic flake in the paint and a urethane clear over that. Are there any issues with spraying lacquer over epoxy? The epoxy used on the hull is MASS low tox.
This boat project is destroying my wallet, But it is enriching my soul.
Re: Lacquer over Epoxy?
Post by Roberta » Sun Feb 26, 2017 1:40 pm
I think the lacquer on epoxy will be okay, but the urethane over lacquer could be a problem. I would do a test of all three.
jeff k
Post by jeff k » Sun Feb 26, 2017 2:05 pm
Thank you Roberta,
The urethane over the lacquer I have been doing for years. To get the maximum sparkle from the flake I shoot the lacquer first, then 2 reduced coats of clear with the flake mixed in, then 2 coats of normal reduction clear to bury the flake. Give that a dry sand with 1000 grit to knock down the high spots from the flake and then a final reduced clear as a flow coat. Most times no additional polishing is needed if the flow coat is reduced correctly.
I was unsure if the lacquer would soften or lift the epoxy.
Jeff
Post by Roberta » Sun Feb 26, 2017 2:18 pm
My bad. I think I got that backwards. Lacquer is a good paint remover. I would test it on epoxy.
jeff k
Post by jeff k » Sun Feb 26, 2017 6:19 pm
Will do. Thank you.
Nova SS
Post by Nova SS » Mon Feb 27, 2017 5:07 am
yes definitely test that as the thinners used with lacquer often will soften any coatings sprayed upon. I think you will be fine with epoxy but better safe than sorry.
Return to “Painting”
