Power Yak Waterline
DallasT
Power Yak Waterline
Post by DallasT » Fri Dec 03, 2010 6:26 pm
I am building the power yak and have a question that hopefully someone can answer. Is there a way to determine the approximate water line with two people and one battery on board? I am assuming it would be about 450 lbs of cargo. Thanks for the help. DT
Re: Power Yak Waterline
Post by billy c » Sat Dec 04, 2010 5:00 pm
there is a waterline pictured on the plan page pretty true comparing it to the actual photos of it in the water. would scale and use that as a starting point
-Billy
BruceDow
Post by BruceDow » Sat Dec 04, 2010 5:08 pm
If you want to be absolutely sure, you can wait to paint the stripe.. is to float it with the load you anticipate and mark the waterline.
Bruce.
Dow's Monaco Project
DallasT
Post by DallasT » Sat Dec 04, 2010 8:25 pm
Thanks for the responses. I think I will try scaling the drawing. That seems like a reasonable method to get close. DT
Return to “Electric Power”
