switch breaker panel ...no fuse ?
If you use a switch breaker panel you don't need fuses right?
- Attachments
- $(KGrHqVHJBsFC18!)6-iBQ)edbnnyg~~60_1mmmmmmmmmmmmmmmm.jpg (16.73 KiB) Viewed 4216 times
Re: switch breaker panel ...no fuse ?
What I mean is you don't need a fuse block if you have the switch panel breaker panel.
- galamb
- Contact:
No you wouldn't need a fuse block.
I believe you might find fuses "under" those little domes adjacent to the switch (or they are possibly breaker resets for breakers built in to the panel - my "vision" is poor
If you simply use "toggle" switches of whatever description then you would need either a fuse panel or in line fuses to protect the circuits.
Graham
Yes, Plywood is "real" wood
A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it
