Paddle Boat with trolling moter. Help!
PaddleB
Post by PaddleB » Mon Feb 22, 2016 7:16 pm
Hello everyone!,
I am new to this forum and need some help. I have a sun dolphin older paddle boat that came with a motor attached in the aft of the boat. I found the motor was bad and was starting the process of replacing it. During this process I decided to remove the paddle part of the boat and decided to move the trolling motor to the front.
Here in lies the problem. I decided to keep the existing wiring concept and was going to run the leads from the motor to a panel that has two switches. One switch has ( FWD, off(middle) and down as reverse)
Second switch has 3 as well. Up( low), middle (med) and down(high).
I need to find replacements for these. However, I can not find any numbers on the switches or anything. So far no help from manufacturer or any where I have been so far.
I will attach a picture or two of the switches.
aero_dan
Re: Paddle Boat with trolling moter. Help!
Post by aero_dan » Sun Sep 04, 2016 8:06 pm
Greetings PaddleB, looks like you did not get a reply. I just found your post and here is my two bits worth:
These are double pole, double throw rocker switches. I just went to eBay and entered just that. I found an assortment of some 92 options. There are some the exact size, and in colours, illuminated, etc. Yours are a "full size" or "standard size" footprint, so the others will be too small for the holes. You cam make filler plugs and a thin metal cover plate, or there are a number of PVC materials to do the trick also.
Hope this is not "too little, too late". Troll on!
Better, faster, cheaper. Only ever found 2 of the 3! (But still lookin.)
So many boats, ...so little time.
Return to “Electric Power”
