Tom's Tahoe
Re: Tom's Tahoe
Post by TomB » Mon May 21, 2018 11:00 am
After a number of months dealing with other things, I’m back building again. The transom sub-assembly weighed in at about 60 lbs of clumsy bulk. It was jacked into place and glued and screwed to the keel, motor stringers, and chines. I managed to get it correct for and aft but put in a little twist from side to side, about 1/8”.
Faring out the twist was a pain in the transom! Among other things, the transom corners that I spent so much time carving to meet side and transom planking no longer fit and I no longer trusted the side faring as it approached the transom so I blocked in the corners and re-fared the transom and sides.
Two layers of planing are now on the sides and transom. The curve of the transom from vertical toward the deck is really tight and was hard to bend with 4 mm ply.
The plan is to rabbet the transom to side corners after the third layer of planking goes on the bottom and then carve and install corners boards so the ends of the final layer of transom and side planking will be covered. (similar to other Tahoes)
Re: Tom's Tahoe
Post by TomB » Mon May 21, 2018 11:20 am
The plans call for three layers on the bottom and two layers on the sides (plus a finish layer).
Three layers meeting two layers at the chines works fine. But the plan is for the chine to fade out as it approaches the stem creating an issue (4 mm step) where three layers meet two layers.
I decided to fare the first layer of bottom planking to eliminate the 4 mm step at the stem. A pro probably would have rabbeted the stem and chine log to keep a full third layer. (I don’t have the skill or energy for such things.)
The first layer of side planking will ride over the first layer of bottom planking and become the second layer of bottom planking.
Re: Tom's Tahoe
Post by TomB » Mon Jun 11, 2018 2:52 pm
The first layer of side planking runs over the first layer of bottom planking and begins the second layer of bottom planking at the stem. The second layer of side planking is complete and begins the third layer of bottom planking.
This photo shows all three layers. Layer one bottom planking is light colored area in the upper right corner. Layer two bottom planking (bottom end of layer one side planking) is along the stem at the top. Layer two side planking is the bottom area, and there is one small plank that is the beginning of the bottom third layer.
Re: Tom's Tahoe
Post by TomB » Mon Jun 11, 2018 3:00 pm
I’m a little further along on the port side, two layers complete with the first of the 3rd layer on the bottom planking.
The red circle is about where the chine will vanish as it approaches the stem.
Re: Tom's Tahoe
Post by mrintense » Mon Jun 11, 2018 3:20 pm
I had to do a double take on the transom photo. I had forgotten about this part of your build . I still feel this is going to be a real stunner when finished. Don't worry abut the fit problems, I am sure you'll figure out solutions. I don't think there is a boat made that doesn't have something not quite right on it.
Looking forward to seeing your boat after you get the hull finished and flipped over. Nice work Tom.
Re: Tom's Tahoe
Post by TomB » Tue Jun 12, 2018 3:52 pm
Carl, thanks for the encouragement. I finished the second planking layer today and started the third layer on the bottom. With two layers on the entire hull, I think it would actually float! I'm anxious to start on something that will show.
Re: Tom's Tahoe
Post by mrintense » Tue Jun 12, 2018 3:54 pm
TomB wrote:Carl, thanks for the encouragement. I finished the second planking layer today and started the third layer on the bottom. With two layers on the entire hull, I think it would actually float! I'm anxious to start on something that will show.
I know the feeling. I feel like I've been making parts forever. Eventually I'll have enough parts to actually assemble the interior! :D :D
Re: Tom's Tahoe
Post by TomB » Tue Jun 12, 2018 4:45 pm
I have been sanding for flatness in preparation for the next planking layer, belt sander and then an air file. It works ok until it doesn't. My air compressor says intermittent air file work is ok. Now that I understand how much is too much for intermittent I can go ahead and replace the smoked the motor starter capacitor.
Re: Tom's Tahoe
Post by TomB » Sun Jun 24, 2018 7:08 pm
Planking continues. The last of the plywood layers went on yesterday. Today I tuned up the chines and keel/stem. After working on it for months it feels like a major milestone. The surfaces are almost fare. Another day will be spent going over the hull with most attention on the bow and the chines at the stem.
A layer of plywood has also been added to the step in the transom. The step is about 5 inches above the waterline. The plan is to plank from bottom to step as part of hull planking. The step, scallop, and remainder of the transom will be planked with the deck.
A waterline has been drawn and I’m starting to line out the final layer of spiled planking. The instructions suggest 1 1/2” to 3” planks. I’m thinking I would like something a little wider. I will draw planking lines on the hull to see what looks good. I am anxious to get started on something that will show. Spiled planking will be the next step.
neel thompson
Re: Tom's Tahoe
Post by neel thompson » Mon Jun 25, 2018 4:42 am
She looks great Tom. I think the transom step you created is the nicest modification to Glen-L plans I have seen. I hope to see your Tahoe close up some day..... You are a true craftsman.... Neel
BillJ
Re: Tom's Tahoe
Post by BillJ » Mon Jun 25, 2018 4:53 am
:D Looks great to me!
Re: Tom's Tahoe
Post by JimmY » Mon Jun 25, 2018 9:31 am
If I build another boat, I'm going to steal that transom idea! 8)
Re: Tom's Tahoe
Post by mrintense » Mon Jun 25, 2018 12:42 pm
I agree with the others, that tail end is going to get a lot of attention. Really nice work Tom.
Re: Tom's Tahoe
Post by TomB » Mon Jun 25, 2018 4:05 pm
Neel, Bill, Jim, and Carl, Thanks for the kind words.
me too...me too...
Today I gave the hull a full rub down. According to the front of the air compressor, it is ok to use an air file for intermittent use. Well...I still don't know how much use is "intermittent". The compressor cycled a couple of times before it stopped, again. :oops: :oops: :oops: The good news, I bought a spare capacitor and can repair again.
I made a long sanding board and finished sanding by hand. After five hours of hand sanding with a long board and 15 minutes of pushing around an air file, I prefer the air sanding...if I can keep it running.
Maybe I can line off the hull tomorrow and then get after the rabbets on the transom corners.
Mike_P
Re: Tom's Tahoe
Post by Mike_P » Tue Jun 26, 2018 12:05 pm
Here's an electric alternative. a little pricey though...
https://www.vektools.com.au/rupes-elect ... ander.html
