It is currently Thu Jun 20, 2013 3:37 am
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon Jun 06, 2011 7:19 am
I may be changing the hull for my build?
Here is a head on of the True Grit and the wide Titan. :roll:
Planing or displacment???Little smaller side deck.
PostPosted: Sat Jun 11, 2011 7:44 am
Now here is a boat (Model) test.
I may need to try this in my idea. :roll:
http://www.youtube.com/watch?v=IeNc3rDT ... re=related
PostPosted: Sat Jun 11, 2011 7:53 am
They got that design/ballast down good!
Only fully capsized at the end when they manually flipped it....but not in the surf.
PostPosted: Sun Jun 26, 2011 6:07 pm
So,i went to work on the 1/4 scale 16' Tug for my Granddaughter.
I will use C-Flex for the 16 ' one :) and see about Alum for the bigger one? :shock:
This 16' one is kindoff a blend of the tugs i have been thinking about. Power will be 4c Merc 9.9. maybe with power trim??? Working on the deck cover that will hide the motor.
PostPosted: Sat Jul 02, 2011 8:08 pm
A little work on the keel and motor mount. The two lines are 15" and 20" transom. Still working out the sheer?
A little hot in the work area. 106????LOL :roll:
The keel is a 1"x3",in scale it is 3"x6" maybe a little BIG??
PostPosted: Sun Jul 03, 2011 9:09 pm
You must think something? LOL
Here are the bulkheads cut out.
PostPosted: Mon Jul 04, 2011 2:26 am
Holiday w/e ....everyone out boating!!!!
Looking good,still not sure how long this is,or what it's for ....I suppose it's a smaller version to see how the mods go???
PostPosted: Mon Jul 04, 2011 8:19 am
She would be 16' long and 8' wide. In scale she is 2' x 4'.
Maybe more of a test for me? :? Just to see if "I" will finish it. :roll:
Also working out the C-FLEX mounting.
Happy 4th. :mrgreen:
PostPosted: Mon Jul 04, 2011 6:20 pm
Some more work.
PostPosted: Tue Jul 05, 2011 8:31 pm
Been working on the rear area at the transom. Thinking about a step? What have you seen out their or tryed?
PostPosted: Sat Jul 09, 2011 9:28 pm
Started to trim things. How much do you think is built into the plans? 10%??
I will start to cover the sheer and maybe some of the bottom? Thinking about 70% of the sheer and 100% bottom? Why do most finish up from the sheer? I'm still working on the deck line.
PostPosted: Sun Jul 10, 2011 7:41 pm
Spent about 5 hours working on the prototype today.More skining to do.
My hat is off to you guys that work in wood! Sanding , planing, work!!
Mush to do! :roll:
PostPosted: Mon Jul 11, 2011 9:59 pm
LOOK! I'm a aircraftcarrier? :lol:
No,but I needed to remove the inside frame screws.
Just try that with a fullsize setup! :roll:
But you can get a better idea of the hull seating upright.
Will need some glass soon? :wink:
PostPosted: Thu Jul 14, 2011 9:51 pm
Finished the bottom and now will cover it with glass. :lol:
So, what do you think about it so far??? :roll:
Well it is almost a real boat. 8) Just 1/4 scale. :mrgreen:
PostPosted: Fri Jul 15, 2011 3:32 am
If only a full scale one would go together that fast. :D
John Amundsen
Monte Carlo
Winter Haven, FL
