It is currently Sat May 18, 2013 9:47 am
Post new topic Reply to topic  [ 9 posts ]
 Post subject: Barrelback bottom batten
PostPosted: Mon May 07, 2012 7:53 pm
I having trouble on the batten, closest to the keel: do I need to steam and twist or cut back flat, then fair. Thanks Bill
PostPosted: Tue May 08, 2012 4:06 am
There are two ways to handle this.
1. Steam and bend
2. Slice the batten into thinner strips and laminate it in. The thinner strips will bend a lot easier for you without steaming. I did mine this way.
Video of Midnight in Action
Blog
PostPosted: Tue May 08, 2012 7:00 pm
Bbeck the way i bent my battons chines=shears i fixed them to the bow first ,then pulled them down and around slowely,you
have got more control doing it that way ,even if it takes a couple of days you will have a nice even bend, this worked well
on the Riviera ,but the Barrelback looks to have a sharper bend, you could even wrap a wet rag around the first couple of
feet to help soften it. it is great to see another barrelback being built keep the pics comeing........
Old Aussie ...Peter
PostPosted: Tue May 08, 2012 9:34 pm
Thanks Dave and Peter For your responses. I''ll starting twisting it and soaking it for a couple of days, then steam if I can't get enough give. Thanks Bill
PostPosted: Wed May 09, 2012 7:08 am
I did not bother with the steam and twist. On mine, I let the battens come in at the same angle as you did. What I did do is leave it high and then planed down a flat area for the planking to attach. The cross section near the bow is more triangular than square. i.e cut back flat and fair.
The 1/4 - 3/8 inch of material removed is not a big deal. The bow area is so small and closed in, there is a lot of support there.
Regards,
Bob Perkins
My Current Projects
http://h12restoration.shutterfly.com/
http://nutshellpramconstruction.shutterfly.com/
My Completed project
http://biscayne22.shutterfly.com
PostPosted: Wed May 09, 2012 3:56 pm
After working on the Riviera, the Barrelback looks as big as a Pt boat......
Old Aussie.......Peter...
PostPosted: Wed May 09, 2012 4:21 pm
:lol: :lol: :lol: The PT boats were done by many of the same builders as the old runabout designers so the lines are very familiar!
I noticed it when I built the Tahoe.
PostPosted: Wed May 09, 2012 4:33 pm
This belongs to the exhaust Guy I am using. He swears it is a grown up Gentry hull.... ;)
http://www.gumtree.com.au/s-ad/castlecr ... 1001137592
PostPosted: Wed Aug 22, 2012 9:03 am
Hi,
I did mine the same way as Bob did, but put an extra batten in to help support the planking to stop it coggling as much.
Regards
Martin
