Seattle Barrelback progress
Bob Perkins
Post by Bob Perkins »
My Biscayne is 23' - I have a 300HP motor.
It is a non-issue...
Not sure if this helps or not.
Regards,
Bob Perkins
All the Fun Stuff
RobertCugini
Post by RobertCugini »
Remember this is a relatively historic shape, the bow is pretty vertical, and the aft area is pretty flat. Not the best for high speeds, in fact people advise caution at higher speeds as the bow my "hook" in slight chop. It all remains to seen when I get it done!
Have you looked at some of the historical books on Chris Craft and others? I can recommend some. The photos are really interesting.
Robert
Bob Perkins
I'll add to that...
My boat is perfectly flat at the transom.. it is a rough ride in chop.. not big stuff either..
once it gets up to 10-12 knots.. I stay in..
If there were plans that I liked (back then) for a boat with some vee - I would have chosen that in hindsight.
Regards,
Bob Perkins
All the Fun Stuff
alycat
Post by alycat »
Is this the one you sourced.? I have been looking at this one as well, if they can covert it from an alpha to inboard.
"Michigan Motorz has the 4.3L, 4 bbl, Alpha 4V - Complete MerCruiser Engine Package in stock. Remanufactured, MerCruiser 2013, 4.3L, 4 bbl., "Alpha 4V", complete drop-in, turn key engine package. It is rated at 225hp at the prop. "
It a little less expensive than the 5.7 bravo.
I may have asked this before, are you going with the 63a transmission?
Will Manwaring
Shreveport, LA
RobertCugini
I was going to use the fuel injected version, It is more money.
http://www.michiganmotorz.com/complete- ... p-330.html
and I was going to use the Velvet drive rather than the Hurth. That was only the way I was leaning because I haven't bought anything yet.
Robert
Bob Perkins
All,
I got my motor here: http://www.dougrussell.com/
When I was shopping - they beat everyone's price by a significant margin.
Check them out before you plunk down the cash.
(no affiliation to them at all)
Regards,
Bob Perkins
All the Fun Stuff
alycat
Post by alycat »
Thanks for the reference, they do have good prices and selection.
Will Manwaring
Shreveport, LA
benpetre
Post by benpetre »
Can someone correct what i am sure is improper reasoning:
With the same drivetrain (transmission/prop), going from v6 to v8 does not add more top end speed, just better holeshot/acceleration/pulling power...right?
__________________________________________________
Ben Petre
Annapolis, MD
https://www.facebook.com/barrelback19
http://drpetre.com
Building the barrel back 19 ever so slowly.
Boat power is as much about torque as it is about HP. A boat engine is under constant load, unlike a car. HP is mostly about top speed. But, most of us don't run wide open all of the time. Torque gets you out of the hole.
RobertCugini
I added cloth to the second side today. It went much easier than the first side. Guess you learn stuff as you go. I've now got both sides and the transom with cloth on them. A few more coats of epoxy and LOTS of sanding and I should be ready for the bottom. I'm going to mount all the hardware before I epoxy the bottom.
alycat
Post by alycat »
Just beautiful!! Love it!
Will Manwaring
Shreveport, LA
themiser
Post by themiser »
Hey Robert,
I recently found this site and your build and love watching your progress. I just moved to the Seattle area, Port Orchard, and when the time comes, would love to come help with the flip. Also, from preliminary research, I've realized there are a lot of places to go for lumber, I was wondering where you ended up sourcing your frame lumber as well as marine grade plywood.
Can't wait for more progress!
Sean
RobertCugini
Thanks, well I used to run a sawmill in the Seattle area, the last one actually on lake Washington, so the frame material was from that. I saved the best old growth vg Doug fir.
The marine plywood came from Edensaw in Tacoma, and the Mahogany veneer came from Certainly Wood in NY state. I used them because they could supply 1/6th inch veneer, rather than the standard 1/8th inch. I think it made a difference, as it allows a bit more tolerance and sanding if necessary.
Hope to flip mid summer and yes your welcome to come and help!
Bob Perkins
Man I wish I had that much room when I was doing mine...
Looks great :)
Regards,
Bob Perkins
All the Fun Stuff
keith Miller
Post by keith Miller »
Robert:
Looking good!
You know what they say, building the hull is about 25% of the work.
Enjoy!
Keith Miller
