Tahoe 23
Re: Tahoe 23
Post by TomB »
Stunning!
Re: Tahoe 23
Post by DrBryanJ »
Beautiful. Love the colors.
Tony Hain
Re: Tahoe 23
Post by Tony Hain »
Thanks Tom and Bryan. Yes I am pleased with the colours too. I think I will probably finish with a two pack poly clear.
Tony Hain
Re: Tahoe 23
Tony
You'll like the 2-pack poly. But god it stinks!
Tony Hain
Re: Tahoe 23
Post by Tony Hain »
I have finished caulking the deck and coating with a couple of coats of epoxy. Before caulking I mocked up a couple of test boards of planking, On one I caulked with a Sikaflex product from a tube. It was very messy even masking up, I left it for a couple of weeks and then coated with epoxy. Result: the caulking material slumped which would mean I would have to mask up the deck and do it again and the epoxy did not like sticking to the sikaflex. Did some research and it seems that basicly it will only allow water based producted to adhere to it. So among other things that would restrict what finishes I can use for the final coat.
The other test board I caulked with a mixture of epoxy, epoxy white pigment and Q-cell (a fine white filler). I was much happier with this method and it allowed easy final encapsulating with epoxy and didn't limit what type of product I used for the final finish. Some photos of the finished caulked deck which has been encapsulated and today I start cutting out the engine hatch.
Tony Hain
Aussie
Re: Tahoe 23
Post by Aussie »
Merry Christmas Tony,
Looking good! Caulking has turned out great.
Hatch is a scary cut!
Looking forward to more pics.
Re: Tahoe 23
Post by JimmY »
Beautiful deck! Good luck with the hatch, measure a lot, cut once. :D
Tony Hain
Re: Tahoe 23
Post by Tony Hain »
Thanks Jamie. I hope you and your family had a wonderful Christmas. Have you had a chance to take out the boat over Christmas? Yes cutting through a nice finish deck is a bit scarey. Nat as bad as drilling the prop shaft though. I used an oscillating multi-tool. Had a couple of bites off the line but hopefully they will sand out or if worse comes to worse I can use banding around the hatch to cover them.
Thanks JimmY. No major stuff ups, so Im happy with how cutting out the hatch went.
Tony Hain
Re: Tahoe 23
Looks great Tony! :)
denbrlr
Re: Tahoe 23
Post by denbrlr »
Tony,
That looks fantastic.
Lee
Re: Tahoe 23
Post by kens »
That looks really sharp.
Am I correct, there is no stain?
Tony Hain
Re: Tahoe 23
Post by Tony Hain »
Thanks Lee and Kens. No I left them unstained and matched timbers for colour where I could. Main advantage is later on if I have to do any repairs I don't have to try and colour match stains etc.
Tony Hain
Re: Tahoe 23
Post by kens »
That looks bright. I think the brightest 'natural' finish is no-stain.
Re: Tahoe 23
Very nice Tony. I see a beautiful summer ride coming soon.
I'm torn on the the stain and no stain approach to wood finishing. I understand and appreciate the advantages of not staining but I stained most of my cabin interior parts long ago and so I'm trying to decide what to do about it.
Tony Hain
Re: Tahoe 23
Post by Tony Hain »
Quick up-date. Basicly:
.electrics run and fitted. May be a bit of overkill but I installed a Blue Seas 2 battery switch with ACR.
.bilge pump fitted and plumbed
.blower fans fitted
.fuel and breather hoses for the fuel tank fitted
So have to install the engine contrl cables and cockpit panels. These are 1/4 ply and will be covered in a marine vinyl. The floor will probably have a marine carpet.
Once cockpit is done it is final clear coating on the hull, deck fittings and buy a trailer
Dash with gauges
Dash with gauges
Blue Seas 2 battery switch set-up
Tony Hain
