Barrelback 20'
alycat
Re: Barrelback 20'
Post by alycat » Tue Jun 27, 2017 5:51 pm
Making a little progress, fixing to test fit the engine again either these modifications to make it a little easier!! Thanks to the forum for the great ideas.
Removable section in place:
Removable section removed:
Getting the floor supports in place:
Will Manwaring
Shreveport, LA
jenko
Re: Barrelback 20'
Post by jenko » Tue Jun 27, 2017 6:49 pm
Looking good Will
Re: Barrelback 20'
Post by mrintense » Thu Jun 29, 2017 6:34 pm
Nice rework Will!. That will definitely make it easier to access the engine. Another really cool build.
Re: Barrelback 20'
Post by Jimbob » Mon Jul 03, 2017 8:22 am
Re: Removable Beam
What a slick idea!!!!
One of the things that I really like about the forum is that you can see solutions that others have come up with. It sets my mind at ease knowing that I can do the same if the need arises.
Nice work Will!
Re: Barrelback 20'
Post by Bill Edmundson » Mon Jul 03, 2017 8:33 am
Great Idea! After it was too late, I thought of building the Tahoe as a utility with a drop in bridge over the engine. That way you could have both.
alycat
Re: Barrelback 20'
Post by alycat » Thu Oct 05, 2017 3:50 pm
Well, I lost my motivation for a little while, but I have the fire back in my belly!!! I had to get some professional help (ha ha , no not that kind, just yet), mechanical help.... The fourth try at fitting the engine worked when you have experience in the shop!! I have to order some new longer angle for the rear mounts and then we will do the permanent install.
I have also started to work on the dash and the cover boards.
Will Manwaring
Shreveport, LA
Re: Barrelback 20'
Post by mrintense » Sat Oct 07, 2017 10:56 am
Sweet looking motor will. Hang in there, you getting close. Installation looks real clean.
alycat
Re: Barrelback 20'
Post by alycat » Sun Oct 15, 2017 5:58 pm
Sub-floor fitted today and checked the fit of the dash.. And my daughter who is making motor sounds!!!!
Will Manwaring
Shreveport, LA
John56
Re: Barrelback 20'
Post by John56 » Sat Nov 04, 2017 4:32 pm
Will, where are ya Bro?????
Getting slack on me!!
alycat
Re: Barrelback 20'
Post by alycat » Thu Nov 09, 2017 1:45 pm
Engine is in!!! Drive shaft ordered. Next up .... other mechanical stuff !!!
Will Manwaring
Shreveport, LA
Re: Barrelback 20'
Post by Jimbob » Thu Nov 09, 2017 2:35 pm
Looks great Will!
I wish I had my motor in. One of these days i'll install mine.
jenko
Re: Barrelback 20'
Post by jenko » Thu Nov 09, 2017 4:43 pm
great work :D
alycat
Re: Barrelback 20'
Post by alycat » Sat Nov 11, 2017 4:46 pm
Thanks guys... tho gut I would reinforce this frame since I took so much out of it. Trying to relocate the oil filter on the engine and also fixing to get the rudder shaft thing in :wink: Also stained the floorboard, so either I can put somethings my loosely over them or let the wood show..options I suppose...
Will Manwaring
Shreveport, LA
Ozzieboat
Re: Barrelback 20'
Post by Ozzieboat » Sat Nov 11, 2017 9:05 pm
If there is clearance for the half coupling and shaft, to get the most benefit from the reinforcement turn the rear plate upside down.
alycat
Re: Barrelback 20'
Post by alycat » Wed Nov 15, 2017 4:15 pm
I’ll try that, just got the drive shaft in so I’ll see if I can turn it over. Got some other fittings today for the raw water intake and picked up some mufflers that were taken off another inboard at a great price.
Got to seal up the shaft log and figure out where to put the oil filter, finish supports for the rudder etc.
I offset the rudder to the right due to haveing a standard rotation (CCW) , I have a 71C transmission which should also turn the prop (CCW) I hope. My mechanic said that the transmission sometimes is setup to turn the prop CW. I checked the model number with a velvet drive install manual and it says it should be a left hand prop... so I think I am good. Any way to tell without starting then engine?
I know this has come up many times on the forum. Don’t want to redo the rudder hole... Ha ha
Will Manwaring
Shreveport, LA
