Barrelback 20'
Re: Barrelback 20'
Post by mrintense » Wed Nov 15, 2017 4:40 pm
Nice Will. The mechanical part of my build is still pretty far off, but I am glad it won't be as complex as these inboard installations. I'm fairly handy, but never been much of a good mechanic.
alycat
Re: Barrelback 20'
Post by alycat » Sun Nov 19, 2017 7:17 pm
Little more progress... couldn’t flip the metal support, not enough room... got the floor boards in to see how they look, shaft log is sealed and tightened down, and have the rudder bracket all locked down. Still figuring out the raw water intake and where to put the oil filter.
Will Manwaring
Shreveport, LA
RobertCugini
Re: Barrelback 20'
Post by RobertCugini » Sat Dec 30, 2017 4:28 pm
Wow, looking good!
Been working on my barrel also, Laying the top deck...
I'm starting on the engine mounts too, so your pictures are helpful.
Robert Cugini
Seattle
alycat
Re: Barrelback 20'
Post by alycat » Tue Jan 16, 2018 10:22 am
I have made some progress on the cover boards... Need to same the rear end so everything meets properly. All the sub deck is fitted and now just trying to determine planking pattern.
We have about 3 inches of snow, delaying the planning of the planking... Give me some time to finesse the cover boards.
Will Manwaring
Shreveport, LA
Re: Barrelback 20'
Post by Jimbob » Tue Jan 16, 2018 10:50 am
Looking good Will!
This is the fun part of the build.
I'm held up with the weather also. Since i'm outside, I can't apply varnish if rain is in sight.
Re: Barrelback 20'
Post by Bill Edmundson » Tue Jan 16, 2018 11:09 am
Will
Three inches of snow in Shreveport! Crap! It hasn't even started in Birmingham. They say 2 or 3 o'clock!
alycat
Re: Barrelback 20'
Post by alycat » Tue Jan 16, 2018 11:51 am
Yep,, it’s headed your way!!! Shreveport is at a stand still. Go get your hot chocolate on the stove!!
Will Manwaring
Shreveport, LA
Re: Barrelback 20'
Post by Bill Edmundson » Wed Jan 17, 2018 7:28 am
Will
We only got about 1/2" of snow. But, it's only 10* this morning with a 12 mph wind.
JoeM
Re: Barrelback 20'
Post by JoeM » Wed Jan 17, 2018 8:26 am
I'm both jealous of all of your snow and happy that I live in California so I don't have to deal with it. Stay warm and safe!
John56
Re: Barrelback 20'
Post by John56 » Wed Jan 17, 2018 6:15 pm
No snow this time, but too cold for my bones.
alycat
Re: Barrelback 20'
Post by alycat » Sun Feb 11, 2018 6:39 pm
Well after the flu swept through our house and travel for work, I made a little more progress on shaping the cover boards and prepping the hatch. Slow and steady I suppose is the key.
Will Manwaring
Shreveport, LA
Re: Barrelback 20'
Post by Jimbob » Sun Feb 11, 2018 6:44 pm
Looking great Will!
Those coverboards really came out nice! I guess we were worried about nothing.
mickfly
Re: Barrelback 20'
Post by mickfly » Mon Feb 26, 2018 3:30 pm
It looks, to me, like you did not fiberglass the last inch or so of the side planking near the sheer. The inch or two above the green tape? Is that right? I have been thinking about this step and worried that I might have to cut into the fiberglass where the top of the planking meets the cover board.
Mick
RobertCugini
Re: Barrelback 20'
Post by RobertCugini » Mon Feb 26, 2018 9:04 pm
Really interested in how you blend the covering boards.
Mine stand proud as a seperate element but I'm thinking to blend them in the stern.
I'll send pictures... Mine are constructed slightly differently. I deck edge to edge with plywood then am applying a 3/4 inch covering board.
RC
alycat
Re: Barrelback 20'
Post by alycat » Wed Apr 04, 2018 6:21 pm
Mick sorry for the late reply.. I do not fiberglass the sides. I fiberglassed up to about two inches above the waterline. Just stain, sealer, and varnish to the top sides.
The coverboards, I followed Mr Jim, used a filler piece then laminated a solid 4/4 on to of that. Then lots of sanding at the transom. Just go with the hand sanding went you start to get close to the joint of the deck and sides
Been busy with work this spring but I did get the deck planked and getting ready to do the final deck sanding. I have also been working on the seat foundations.
Will Manwaring
Shreveport, LA
