Flats Flyer Build in S.C.
Alexile
Re: Flats Flyer Build in S.C.
Post by Alexile »
Hi there, I've just flipped my Flats Flyer and now I'm going to have a ton of questions. I guess I'll start with a simple one about the transom drain plugs. I will be trailering and I was planning on installing two at the lowest drain points in the transom. My question is, what kind of thru transom drain plug did you use?
specialk
Post by specialk »
This is the best picture I can find...
If I remember...i epoxy a brass tube...to the escutcheon to the back of the transom.....Image
2nd Boat.....?
Alexile
Re: Flats Flyer Build in S.C.: weight of boat?
Post by Alexile »
Thanks, that picture is actually very helpful! I'm searching for a trailer as well, and was wondering what weight I should be looking at? I know I read that the dry hull weight for the Flats Flyer was around 800 lbs. So, with engine, batteries, fuel, water, etc I was wondering if anyone knows the weight? Thanks again!
specialk
Post by specialk »
If I remember mine was 1600lbs..with motor...
There's a company in Charleston SC...that builds trailers...
I talked to 6 different companies when searching for my trailer..he was the only one that said...send him pictures...wanted weight..
And we're I thought my center of gravity was..on my boat...
Thank goodness we have Bill on this forum...
Not sure were you are in the world...but
Charleston Trailer...will always build all my trailer's...
2nd Boat.....?
Alexile
Post by Alexile »
any recommendation / advice on hatches?
specialk
Post by specialk »
Not shure where you live...
But my recommendation is you want a hatch that's very low profile the lower the better that way as you're walking across your decks and different places they don't become a tripping hazard
2nd Boat.....?
Alexile
Post by Alexile »
Has anyone installed a live well? I'm looking into it and I'm hesitant about putting more holes in my hull than are absolutely necessary.
specialk
Post by specialk »
I was going to put a live well in...the space were my transom speakers are at...and I still can...
But I had the same thought as you...it is done in boats all the time....I just could not drill any more holes in my Flyer...
I use a very nice cooler ...and my big one is a barrel cut in half..
2nd Boat.....?
Alexile
Post by Alexile »
I was looking at an older (early 2000's) Evinrude 4 stroke 70hp (when it was apparently really a Suzuki) anyone have any thoughts about pairing this motor with the Flats Flyer?
Alexile
Post by Alexile »
Any suggestions on the Sole Drain? Thru sides or to transom? If to transom how is the water evacuated?
specialk
Post by specialk »
Go to page 10 of my build...
I have a few pictures...it drains to the bottom keel of the boat..
I put a bilge pump on each side of the keel...one pump is automatic...the other pump is manual....
Hope this helps...
2nd Boat.....?
ajwing3715
Post by ajwing3715 »
Hello specialk!
Fantastic information here. Thanks for sharing with all of us. That's a lot of extra time and effort. It is greatly appreciated.
I am sorry if I missed this, but do you have a bit of info on the gas tank install and running power to it?
Thanks!
Alexile
Post by Alexile »
I was wondering where and how you installed your batteries?
specialk
Post by specialk »
I installed 2 batteries in my center console...
If you look back...i show a picture of the wiring in the console ..
The batteries when in front of that wiring...
Hope that helps...
2nd Boat.....?
Alexile
Post by Alexile »
Yes, thank you! I was hoping to move the weight forward like that, but I'm not sure that I have the space in my center console. (Plus I might end up with 3 batteries, a cranking battery and two others set up to be both house and 24 V trolling motor...)
