Extending the Tahoe 23 to 24'2"
Re: Extending the Tahoe 23 to 24'2"
Post by TomB » Tue Jul 31, 2018 6:45 pm
Hmmm, Donn what is your reasoning for not putting flotation above the waterline? It seems that it might useful anywhere you can get it if you need it.
DonnD
Post by DonnD » Tue Jul 31, 2018 8:20 pm
My bad... I meant to say above the water line. One of those problems of building something upside down. :oops:
DonnD
Post by DonnD » Mon Aug 06, 2018 8:39 pm
Relatively current photos. I've added about 10 planks to one of the sides, but should give a general idea a to status. I continue to be awed by the lines of the Tahoe. Ken H was a master!
DonnD
Post by DonnD » Mon Aug 06, 2018 8:44 pm
A few more photos, these related to drilling the propeller shaft hole, I hope may be helpful.
DonnD
Post by DonnD » Mon Aug 06, 2018 8:50 pm
Various stages of the build. I really struggled with where the land the battens and wish I had followed Brad T or Tony H's lead.
DonnD
Post by DonnD » Mon Aug 06, 2018 9:10 pm
Oooops, Didn't mean to post a photo of my children...But not sorry I did! :oops:
A few more photos including the scarfing jig I mocked up (inspired by a YouTube post). It uses sliding drawer guides set at a 10:1 ratio
Post by TomB » Tue Aug 07, 2018 4:46 am
The boat looks great Donn. The slide-route-scarf-a-maker is a new one. What diameter hole did you use for the drive shaft hole?
DonnD
Post by DonnD » Tue Aug 07, 2018 11:13 am
Thanks Tom. The bit I used was 1.75". Per Roberta's post, I'll line it with fiberglass tubing with an outside diameter of just under 1.75" and an inside diameter of just under 1.25". All the dimensions assume the recommended 1" propeller shaft.
Cheers,
Donn
Tony Hain
Post by Tony Hain » Tue Aug 07, 2018 11:47 am
Great work Donn and I agree. The Tahoe has beautiful lines. I loved the skeletal effect before the planking went on to the hull.
Tony Hain
