barrel back 19 in annapolis
Re: barrel back 19 in annapolis
Post by hoodman » Mon Dec 22, 2014 10:06 am
never let your plan set on it blade unless you are using it
I do this all the time. I feel like I'm more likely to nick the blade with another tool if its laying on its side. This is only if your are setting it down on wood and not a concrete floor. Your blade gets more wear from using it than it resting on the blade. Just don't be slamming it down.
benpetre
Post by benpetre » Sat Jun 20, 2015 1:36 pm
A winter off because of a new baby and building a paddleboard, finally made some progress on my bare back
__________________________________________________
Ben Petre
Annapolis, MD
https://www.facebook.com/barrelback19
http://drpetre.com
Building the barrel back 19 ever so slowly.
Gayle Brantuk
Post by Gayle Brantuk » Mon Jun 22, 2015 9:45 am
Looks great! Thanks for posting a photo and congratulations on the new baby!
benpetre
Post by benpetre » Mon Jul 13, 2015 3:22 am
I have got to the point of installing the side batons for framing. I have attempted 2 so far, I have cracked one and split one in the most forward bend.
Does this step require steaming? (I don't own a steamer). Have people had good success with the towel and boiling water? If so, how long do you leave the hot wet towel on before bending? Does it keep its shape after (would need to remove for scarfing and then refit for glueing).
Ben Petre
Annapolis, MD
http://drpetre.com
Post by Roberta » Mon Jul 13, 2015 4:37 am
I would steam them. It is easier and cheaper than a new piece of wood. It only takes about 20-30 minutes to steam a batten using a cheap wall paper steamer (Home Depot) and plastic sheeting (3-6 mil also HD). Make sleeves by rolling plastic sheet and staple edges. Also, try not to drill and screw fastening points at bends.Glue and set with clamps if possible.
chugalug
Post by chugalug » Mon Jul 13, 2015 5:40 am
:D That looks kinda like the steamer that Jamestown Distributors has advertised for 65.bucks or is it?
benpetre
Post by benpetre » Mon Jul 13, 2015 8:42 pm
Thanks Roberta. To HD tomorrow for some new equipment!
Ben Petre
Annapolis, MD
http://drpetre.com
benpetre
Post by benpetre » Tue Jul 14, 2015 9:01 pm
I tried the boiling water over towels and got them in position without cracks... now to secure them
Ben Petre
Annapolis, MD
http://drpetre.com
283cuin
Post by 283cuin » Fri Jul 22, 2016 7:59 am
Ben Petre,
We haven't heard from you for about a year. Since you are the closest Glen L builder in the country to me, Gaithersburg, I'm curious to know how my "neighbor" is progressing.
Regards,
Gene
benpetre
Post by benpetre » Sat Jul 23, 2016 5:59 am
I have been lurking and watching on the boards. Sadly, My build stalled as I built a SUP for my wife and a kayak for my daughter in the last year. I am happy to report though that my raptor staples showed up last week and I plan to go buy a lot of 1/8 okume this week!
Ben Petre
Annapolis, MD
http://drpetre.com
benpetre
Post by benpetre » Thu Mar 15, 2018 11:19 am
HI All-
I am restarting my build after ~ 3 years of very limited activity (my son is now 3 years old :). I am getting close to the mahogany layer for the bottom and have been thinking a lot about how to affix that last layer. i have been using raptor staples so far and absolutely love them. i noticed that if i use the longest staple and not quite enough pressure in my compressor, the staple goes mostly but not all the way in. If i did this in the last layer and then sanded off the tops, do you think the legs would be visible? Or would they stain well and disappear? I have heard of people using the brown brads, but would hate to buy another gun/supplies if i can get this to work. i was planning on doing some test strips first before i committed, but figured the communal knowledge here may be able to guide me.
Ben Petre
Annapolis, MD
http://drpetre.com
Post by DrBryanJ » Thu Mar 15, 2018 11:43 am
I didn't use raptor staples, but if i remember correctly, others have posted that they do disappear once stained.
Post by Bill Edmundson » Thu Mar 15, 2018 11:49 am
Ben
Put a dust mask on that boy and give him his first sander :!: :lol:
neel thompson
Post by neel thompson » Thu Mar 15, 2018 12:23 pm
Hey Ben..... Happy to see you back at it. I think you could use the Raptor staple gun for the planking. Try stapleing through 1/8" scrap strips, then into the planking. Tap the scrap off and sand the staple legs flush. This system works great with the brad gun, but I think it will also work with the stapler. Give it a try. I think all of the Raptor stuff is stainable. Maybe we can get together this summer for a run up the Chesapeake.....Neel
