Neeley's Barrelback - Sacramento
monitor
Post by monitor » Mon Aug 13, 2018 5:20 pm
Jim. When you get a chance give us a picture low and from the rear of the trailer. I was only kidding about the casters, but I would really like to see what they did back there.
Thanks
Jim Kinsella
Post by Jimbob » Tue Aug 14, 2018 8:37 am
Here you go.
monitor
Post by monitor » Tue Aug 14, 2018 9:04 am
Thanks Jim. Yea, that looks pretty typical for a keel drive boat. Do you know what the casters are for? They would never hit the ground the way I see it.
Jim Kinsella
Post by Jimbob » Tue Aug 14, 2018 9:39 am
Don't know. I guess if someone had a steep driveway it would prevent scraping.
Post by Bill Edmundson » Tue Aug 14, 2018 11:46 am
I have a steep drive onto a steep hill! I have also bent a prop on a curb. Yes! I would have them.
deavoll
Post by deavoll » Fri Sep 28, 2018 11:54 am
Your boat is looking amazing, well done.
Can i ask how much of the Interlux stain you used to do the boat?
Thanks, Troy
Post by Jimbob » Sat Sep 29, 2018 8:10 am
Thanks!
One pint of stain will do the whole boat. You thin the stain so it goes a lot further than you might think.
deavoll
Post by deavoll » Sat Sep 29, 2018 5:24 pm
Thanks for the reply, Im in New Zealand and purchased two pints a while back for america. Now it's getting close to stain i was starting to get nervous as it looks like such a small tin but i feel better now,thanks!
Post by TomB » Sun Sep 30, 2018 6:22 am
The Interlux stain should be thinned. Interlux 333 is the recommended thinner (kerosene and naphtha).
Post by Jimbob » Wed Oct 31, 2018 10:18 am
Last weekend was bilge pump weekend.
For proper placement, I had to find the deepest spot in the boat, I took measurements from the top of my motor stringers to the keel at different points. To confirm the placement, I put a level on a motor stringer and lowered the trailer until it read level on the motor stringer. Next, I put water into the boat and used the dipstick technique to make sure I had the low point. Glad I made my floor with removable sections for easy access.
Next, I installed the bilge pump and related float switch, and then pumped water out to test.
After testing I decided that I would add a second pump. Since I will have two bilge pumps feeding into a single outlet, I devised a “Y” fitting so one pump wouldn’t pump into the other pump because rule doesn’t recommend check valves.
The first pump is controlled by the automatic/manual switch. It will be switched to automatic. I didn’t want the modern bilge switch to be seen on my classic dash, so I installed it in a box behind the dash. The switch lever extends slightly beyond the bottom of the dash. The second bilge pump will be manual only and be controlled by a second classic type switch on the dash. Pics Below:
Pump placement. All setup for pump #2. It will be installed to the far left of pump #1
The "y" connector connected to single hull fitting
Auto bilge pump switch mounted on dash far right
Post by Hercdrvr » Wed Oct 31, 2018 11:08 am
Good stuff, thanks for sharing. It’s nice to have you ahead of me marking the path.
Post by mrintense » Wed Oct 31, 2018 11:56 am
Jim, is that a standard PVC "Y" fitting? I have similar hoses and just wondering.
Post by Jimbob » Wed Oct 31, 2018 12:25 pm
Hi Carl,
Yes it is. They are pvc fittings like you would use for sprinklers. The "y" threaded fitting has one opening with a threaded 1/2 opening and two with threaded 3/4 openings. (couldn't find a fitting with three 1/2" threaded openings.) I got reducers that took the 3/4 openings down to 1/2". I then screwed 1/2" nipples into the three openings. The 1/2" nipples are a nice tight fit into the 3/4" bilge hose that I used, so tight that you don't need hose clamps.
Post by mrintense » Wed Oct 31, 2018 3:10 pm
Ah, I see now. Okay, thanks for the feedback.
monitor
Post by monitor » Wed Oct 31, 2018 4:19 pm
Looking good Jim. Is that a push-pull cable attached to a Chris Craft shift lever I see there?
Jim Kinsella
