FF in Kathleen GA
Re: FF in Kathleen GA
Post by Jimbob » Tue Nov 26, 2019 10:41 am
I have used both methods of applying fiberglass cloth. The dry method is much easier in my opinion because you can position the cloth easily, hold in place with tape, and then spread the epoxy on top of it. I gave the hull a good coat of epoxy and let it dry before laying the glass down. That way the wood doesn't suck the epoxy away from the cloth. I overlapped the two sections at the keel, and then added a 3" or 4" cloth tape on top of that.
Pic of my process below.
Fiberglass has been applied on the left side.  Right side about to be applied.
Conrad
Post by Conrad » Tue Nov 26, 2019 12:03 pm
Thanks Jim!
Keep your lines tight!
Conrad
Conrad
Post by Conrad » Wed Nov 27, 2019 9:44 pm
I know it is darn near sacrilege to state anything against the process to some, but wouldn't it be just as effective to thicken the encapsulation coat prior to laying the cloth so that you could skip the filling screw holes part?
Also, Happy Turkey Day
John
Conrad
Conrad
Post by Conrad » Sat Nov 30, 2019 8:08 pm
Well, she's ready for the final once over of screw filler. She shaped up nicely!
I posted in the epoxy section, but I am pushing the pause button for 4 years as the military has decided to send me to Germany. We are trying to decide if we should epoxy, glass, and prime or just epoxy and glass. Thoughts?
John
Conrad
Post by hoodman » Wed Dec 04, 2019 6:58 pm
Most folks will advise a two-week cure on the epoxy before you try to start with painting. So if you are crunching for time you could stop there. Should be no problem with leaving it to sit for 4 years with just fiberglass on it especially if it's being stored inside. The hull looks great!
Post by mrintense » Sat Dec 07, 2019 6:47 am
Let it sit without the paint. Try to do what you can to mitigate any mold growth from humidity.
Conrad
Post by Conrad » Wed Jan 01, 2020 8:07 pm
Well, Tomorrow is the big day. I put 1 coat of epoxy on the boat, sanded it, then put another coat in areas that I had to sand to bare wood. At least now, there is 1 coat of poxy shield over the entire boat before storing it. I made the cradle. The boat trailer I bought was too short, so we sold it. Instead, we are renting a 26' Uhaul and will be flipping the boat and loading it onto the cradle inside the uhaul truck tomorrow. Hopefully nothing bad happens. Friday, we ill drive it to Virginia where she will be stored in the barn for 4 years while we complete our tour in Geilenkirchen Germany.
Conrad
DavO
Post by DavO » Thu Jan 02, 2020 7:59 am
Thanks everyone for the great pictures! I have a stupid question for the group. What is the best way to remove the epoxy-dust after sanding the first epoxy layer. A damp cloth? A tack clock? Anything else?
Post by Bill Edmundson » Thu Jan 02, 2020 8:04 am
DavO
Soap and water. It gets the dust and helps remove any amine blush.
Conrad
Post by Conrad » Fri Jan 03, 2020 7:43 pm
Well, I had way too many friends show up and help...good problem to have...it was like tossing a chunk of wood. She's flipped. I tried a 26' Uhaul, but the opening was too small, so I returned it and got a Penske. We unload it in Virginia tomorrow.
Conrad
Conrad
Post by Conrad » Fri Jan 03, 2020 7:45 pm
Conrad
Conrad
Post by Conrad » Sat Jan 04, 2020 3:22 pm
Well, she's placed in her long term resting spot with her cousin Avery
Conrad
Post by Bill Edmundson » Sat Jan 04, 2020 4:10 pm
:) Keep in touch.
Post by mrintense » Sun Jan 05, 2020 4:23 pm
Good luck with your tour. Been in that position myself many many years ago.
