FF in Kathleen GA
Re: FF in Kathleen GA
Looking good. It's fun when the frames start to come together. I would recommend doing a couple of encapsulation coats on the frames while you can lay them flat. I'm really glad I did so.
Conrad
Post by Conrad »
Thanks. That's the plan. I will glue them up first, set up the level line, dry fit the stem/transom knee and then encapsulate the frames and put it back together.
Keep your lines tight!
Conrad
Conrad
Post by Conrad »
#4 is glued up! Slightly deviated from the plan. Progress...
Conrad
Conrad
Post by Conrad »
2, 3, & 4 are on the form. 1, 5, & 6, as well as the Transom Knee are prewetted and ready for glue up tomorrow.
Conrad
It's fun when you start to see the frames describing the shape of the boat on the building form!
Conrad
Post by Conrad »
Frames 1-6 are built, 4-5-6-stem are being encapsulated. The transom knee has been built and encapsulated. I won't work on the boat tomorrow. Flying & the epoxy needs time to cure anyways.
Conrad
Conrad
Post by Conrad »
I've realized that I'm horrible about noting people's responses on this thread. If you've commented or responded to a question, your advice and comments aren't ignored :). Work and 3 toddlers can keep me pretty busy ;) Thanks!
Conrad
Conrad
Post by Conrad »
Here is a photo stolen from another boat builder on is hull strakes. I really like the look of them on the hull. Thoughts?
Conrad
specialk
Post by specialk »
I think that would be beautiful. ..
By the time I got to that point...I wanted to get it done...and painted. ...so I picked a different way...!
2nd Boat.....?
It's great if you like how they look but once you flip the hull you'll never really see them. So unless you have a specific reason to have them it's a lot easier just to fit a skeg. This is from the Glen-L catalog: "Regardless of power, FLATS FLYER pops on plane in an instant without noise-inducing lift strakes."
Conrad
Post by Conrad »
Fair. I read that, but I also know it has a hard time with sliding because of it as well.
Conrad
Conrad
Post by Conrad »
Frames are now hanging on the form and half of the transom is built.
Conrad
Conrad
I like this stage! It's your first look at the real size and shape of the boat!
Looking good! Now you get to see the shape full size. That boat is a great design.
tcough
Post by tcough »
You're making great progress Conrad and will be caught up to me in no time. This was the exciting part of the build for me so far, seeing it take shape and starting to get a feel for the size. After the flip, you'll really appreciate how much room is in it.
Happy Boating,
Tracy
Building a 19'-9" Flats Flyer
