FF in Kathleen GA
Conrad
Re: FF in Kathleen GA
Post by Conrad »
tcough wrote:You're making great progress Conrad and will be caught up to me in no time. This was the exciting part of the build for me so far, seeing it take shape and starting to get a feel for the size. After the flip, you'll really appreciate how much room is in it.
Sooooo, I’m getting ready to mark out and cut the transom....did you set 14 degrees on a bandsaw? I wish the plans would have just marked both lines...
Keep your lines tight!
Conrad
tcough
Post by tcough »
I did cut it to 14 degrees, but because of the size of the transom, I used a jig saw and left it proud by about an 1/8th inch. While fitting the battens, I trimmed to final size then attached them.
Happy Boating,
Tracy
Building a 19'-9" Flats Flyer
specialk
Post by specialk »
Conrad...there are several ways to get that angle...
If you have the room...your bandsaw method is perfect. ..
If you are good with a jig saw Tracy ...has a good idea. ..
I stole this pic..from someone on the fourm...just to show you what I did..
My thought was. ..once the battens were in...I could use there straightness to get a better angle on the transom...
Conrad...I did a screen shot...on my phone...it will not let me pull it up to attach it to this thread. ..we are living in fla..now...and have no inter-net or cable...and I kind of like it...but anyway will email it to you...
Good job on the build...you are progressing fast...!
2nd Boat.....?
tcough
Post by tcough »
Kelly - where in Florida?
Happy Boating,
Tracy
specialk
Post by specialk »
Port St. John... directlyacross from the VAB at Kennedy Space Center
This is the view ...we wake up to every day...
2nd Boat.....?
Conrad
Post by Conrad »
Stem is glued up and ready to be trimmed and the plywood backing of the transom is being glued tonight...note my sophisticated clamping system.
Conrad
:lol: Do you mean that you don't have to keep the little guy up all night sitting on it?
Conrad
Post by Conrad »
Does anyone know why Glen L doesn’t include the bots in the fastener kit?...weird..
Conrad
Conrad wrote:Does anyone know why Glen L doesn’t include the bots in the fastener kit?...weird..
That's a good question. It does leave open the option to use hot-dipped galvanized but you might as well use Silicon bronze. It's a pretty small percentage of the cost of the build overall. In the end, Glen-L was the only place I could even find the size I needed for the Geronimo.
Conrad
Post by Conrad »
So rookie question.
Here is the assumption:
Once the transom Knee is attached, attach to frame 1 with the keel and then to the stem. Once complete, move to the chine...is that the correct order?
Conrad
Conrad
Post by Conrad »
So today, I trimmed up most of the gussets, laminated the bottom pieces on the transom(since I jacked up the only piece I had wide enough) spaced out the frames to the proper length, cut the keel notches on all the frames and dry fitted the stem and keel. I measured it out and I think my final size will be 20’ 4”. I’m not sure where I ended up with the extra 7”, but I’m not complaining! :lol:
I’ll cut the batten notches into the transom, and cut the chine notches into the frames tomorrow.
Kelly and Tracy, did you notch the transom and then just lay the battens out to decide where to cut the notches? Also, did you have to scarf any battens? If so, where did you choose to place the joint? For the Chine, did you use 1” nominal or actually plane to 3/4? I have been using 7/8” net and am thinking of keeping that for the chimes. Thoughts? Lastly, Did you epoxy frames 5 & 6 at the stem joint or just screw them on?
Thanks for answering my thousand questions!
Conrad
specialk
Post by specialk »
I did have to scarf..a few of my battens...if I remember I tried to break them over a frame...
The chines ....the one where bottom of boat meets gunwale...I think I too did 7/8....
The chines ..where deck of boat meets gunwales...
I believe that needs to be 5/8...because you have a great bend in the bow...plus you need up laminating that with 2 pcs.. plus adding a pc...between frames in the bow area..
I epoxy everything that could be glued. ..
2nd Boat.....?
tcough
Post by tcough »
I notched the transom before laminating it and placed the battens roughly parallel to the keel. Marked their location, then cut the frame notches. I did laminate a couple of the longer battens, locating the joint as far aft as possible. You'll have a pretty wicked bend in them up near the bow, so avoid laminating in that area and use lots of steam and something to hold them down (up?) while placing the ply sheeting. I used wire attached to screw eyes and the building frame.
Chines I believe were 3/4" (1" nominal) stock. Be careful here too at the bow and use plenty of steam (this goes for the shear too). Given enough time/steam, I think you could wrap stock around a pencil.
So far, I've used epoxy at all connections where screws were used. At the sheathing to frame connection, only epoxy, no screws. I did notice the other day, while planning to start work on her again, that several screw "divots" could be seen. I may be too far along to go back to them, but it's not a show boat. The juice may not be worth the squeeze.
You're making great progress. I can't believe it's been almost 2 years since I last worked on mine, but will be back at it soon.
Happy Boating,
Tracy
Conrad
Post by Conrad »
Thank for the responses. I will probably cut out the chine notches, but I have a 2 week TDY and won’t be back until mid March, so I will be taking a break.
I’ll post some updates then
Conrad
tcough
Post by tcough »
Those TDYs always come up at bad times. I just returned from a week long TDY to Laughlin AFB, could have been working on the shed but no, Air Force needs come first!
Happy Boating,
Tracy
