Page 7 of 12
Re: Texas Barrelback 20
Posted: Fri Jun 29, 2018 6:13 am
by billy c
steves wrote:I suppose I will give him the dimensions he wants, if its short I can add a spacer between tranny and prop couplings.
Dimensions in writing :roll:
Posted: Sat Jun 30, 2018 6:40 am
by steves
Hi Billy,
I've communicated all via email with the exact information presented previously and copied herein.
I calculated my shaft length to be 45 3/4" long with the following beyond the strut (1" diameter shaft):
-standard SAE taper 2 3/4"
-standard SAE beyond the taper 1 3/4" (leaves room for threads and cotter pin)
-1" space between prop shaft and strut
for a total of 5 1/2" beyond the strut.
My prop shaft guy says I need 4.6" beyond the strut (says that will give me 1/2" clearance between prop and strut).
I'm not sure how much clearer I could have been in my communications.
Posted: Sat Jun 30, 2018 6:51 am
by billy c
That is clear.
I’m sure he doesn’t want to recut a new prop shaft for you. All the places I’ve dealt with have made sure things were right so if it is that kind of business all will turn out well. Is he doing prop too?
Posted: Sat Jun 30, 2018 6:52 pm
by steves
Billy, I've got more research to do on the prop but he could provide that as well. Its discount inboard marine which is where I got my motor too.
Thanks again for your help!
heater hose
Posted: Sat Aug 18, 2018 9:08 am
by steves
hey Guys,
I am re routing my coolant overflow tank to the back of the motor. I need to cut and put in 2 90 deg fittings. Any suggestion for 90 deg barbed hose fittings?
I've not found a supply yet. Considerations are brass or stainless I suppose.
coverboards on!
Posted: Sat Aug 18, 2018 10:32 am
by steves
these were a pain, but I enjoyed them, now to cut off 500 plugs!coverboard joint 2.jpg[/attachment]
Posted: Sun Aug 19, 2018 7:51 am
by JimmY
Those joints look great. Can't you use shorter plugs?
Posted: Sun Aug 19, 2018 9:28 am
by Hercdrvr
Cool detail. Chris Craft never had time for a joint that nice.
Posted: Sun Aug 19, 2018 10:23 am
by steves
JimmyY,
I found that with my plug cutter, the longer the plug, the more it tapered and fit in the hole better.
Cutting them off with a vibrator saw is only about 2 seconds each and it doesnt matter how long they are!
Hercdrvr, Thanks!
Posted: Sat Aug 25, 2018 1:05 am
by psychobilly
Love all the sawdust present on the walls, well everywhere. ;-)
Posted: Sun Aug 26, 2018 6:55 am
by steves
psychobilly,
I cleaned it all up 3 years ago, and within a week it looked just the same, now I only clean at critical points of varnishing!
The other excuse could be, I have successfully overcome ADD and Anorexia!
How's Australia (I'm jealous)?
Posted: Sun Aug 26, 2018 2:27 pm
by psychobilly
lol
OZ is awesome except my family ain’t here.
Posted: Fri Oct 05, 2018 3:55 am
by psychobilly
steves wrote:Billy, I've got more research to do on the prop but he could provide that as well. Its discount inboard marine which is where I got my motor too.
Are ya dealing with Vance there at SKIDIM? I know I have spoken to him several times while out on the water or in the shop and he has always got me back up and running or at least solved the problem. Very knowledgeable guys at SKIDIM.
exhaust hose source
Posted: Fri Nov 09, 2018 3:18 pm
by steves
Hey Folks,
I've started my search for exhaust hoses. It seems I need about 7 ft per side of 3.5 in hose.
I like the vetus stuff but cant seem to find a source that sells less than a role of 66"! can anyone help a guy out on a source that sells by the foot?
Thanks and hope you are all well!
Posted: Fri Nov 09, 2018 4:22 pm
by billy c
Hamilton Marine sells it by the foot
