20ft Texas Barrel
Re: 20ft Texas Barrel
Nice, glad you're okay.
The strut off my Supra parts boat is a 14 degree, I’ll have to buy a 16 degree. I’ll bring the 14 to the Gathering next year if anybody needs it.
It’s all coming together, time to cut out part of the frame to make room for the transmission.
Matt, a 14* strut is perfect for a Tahoe. Tom
Look closely at the plans. The Tahoe bottom slopes up at 2*. That would make a 14* effectively 12* to the set-up line. The BB maybe the same.
Post by Jimbob »
Hi Matt,
In looking at your picture it looks like you have the trans mounted at the top of the motor stringers.
It might just match your angle if you drop the transmission down lower. See the link below for alycat's barrelback. His transmission drops down below the top of the motor stringers. Just a thought...
https://www.glen-l.com/phpBB2/viewtopic ... at#p201485
I’m about to start shaping the edges of the cover boards on the Barrel-back. To get the flowing rounded edge I bought a handheld pipe sander. Playing around with it on scrap wood is working well.
Post by billy c »
Cute device. :D
I found a block plane to be handy too as the coverboard rolls into the barrel. Longboard work to avoid concave surfaces to happen in the long fair transition into the sides.
Fair lines
Billy
Process report, carling glued and screwed, deck battens cut but still loose.
DavO
Post by DavO »
Very nice Matt - enjoying this slightly-warmer weather!
For a hillbilly carpenter like me, it’s looking ok. I’m leaving the cover board proud of the hull, allowing the flairing lines of the hull to continue up the cover board then rounding to the topside.
DavO, friend and fellow Barrelback builder saved the day this weekend. He came by just after I had glue up 2 pieces of Walnut and noticed I’d done it backwards. He saved 1/2 day of work.
All your boats look great, this one will be no different.
Two extra thick (8/4) cover boards screwed and glued down. DavO cut a handful on Walnut plugs for me. Those two boards are under some pretty serious tension, they bend and twist to conform to the sheer. I’ll give the PoxyGrip a few days before pulling clamps.
BayouBengal
Post by BayouBengal »
That's some beautiful grain on them coverboards. It's going to really pop when you put the finish on them. :D
She’s coming along. It takes a while to round the Black Walnut edge so it flows nicely.
Post by billy c »
That looks good. It's best to leave a small flat on the join for the rub rail to sit
