20ft Texas Barrel
Re: 20ft Texas Barrel
Post by DrBryanJ »
Looking really nice Matt.
Gantry cracked and popped a little, just enough to make me feel extra alive as the engine hoisted to the 4 ft required clearance for the boat to slide under.
About $75 for all the materials, ten 2x4’s, screws and a 2 ton chain hoist. I wonder where it would fail if I increased the load?
Installed
boisebrit
Post by boisebrit »
Nice Job and love the home made gantry.
Awesome homemade gantry. It would take a lot more than an engine to make that fail. That's an exciting day to get the engine in it's home.
https://youtu.be/rKS8f_a-g7U
Lowering the engine in, if anyone is interested.
Small set back today, The engine and transmission mounts were frozen after 27 years. Had to hoist the engine again a few inches, pull the mounts and get some heat on them. I probably could have heated them on the engine but I didn’t want set it on fire. I’ve had the rubber in engine mounts catch fire, it gets a little exciting.
Sometimes it takes fire to build a boat.
Post by vupilot »
It looks like its ALWAYS at little exciting in that garage of yours! :D
It's been awhile but everything looks great Matt. Nice work on the gantry. Getting the engine mounted will be a great milestone. I think you made the right decision to heat those mounts separately. While I was away, I had some first hand experience with burning wood and it goes up very quickly!
Needed fasteners for the bronze strut, stainless fasteners are 1/3 the price of bronze, so “why not” I ask. I found a good read on what metals can be mixed. Looks like bronze and stainless are not ideal but ok together, the best answer is use the same materials. Any thoughts from some of the big brain chemistry folks?
https://www.fastenal.com/content/feds/p ... rosion.pdf
Got the rudder loosely installed and new packing glands in. I had to belt sand down the keel about 1/8” so the packing nut could snug down and seal properly. I will have to trim out a section of the 3/4” plywood transom so the rudder arm will have room to have full swing.
I had to cutout a section of the transom between the camber boards for the rudder tiller arm to swing. No big deal, I kind of like having access to this area so no water takes up permanent residence in there.
I had a question about my rudder not being offset. I hope it’s not a big mistake but the Supra ski boat my parts came off had the rudder dead center inline with the prop with no problems. We’ll see.
What should I seal the rudder with, 3M 5200 or 4200?
I'm not sure what you're saying. But, I hate 5200.
