20ft Texas Barrel
Re: 20ft Texas Barrel
All useable parts removed from the Supra Ski boat so she got hauled to the boat crusher today.
https://youtu.be/GhCkpZAobXE
Wow, nice Big Block Burban! Did you do burnouts yet?
Can you use the Supra trailer for the Barrel?
Hoodman,
The trailer is the 2nd reason (engine 1st) I bought this particular boat. I will cut off bunks and re-weld them to fit the narrower Barrelback. I might add a $500 surge brake kit, I hate trailers pushing me when I’m trying to stop.
As a point of interest, the Supra hull with almost nothing left in it weighed 1480 lbs. That’s a lot of epoxy and fiberglass.
The 572 CI Suburban tow vehicle has a very high giggle factor when you stomp your right foot. Too scared to try a 4wd launch for fear of breaking something, best to have lack of traction be the weakest link.
And the Barrelback hull is 875. Should be a good performance jump from the Supra.
It’s that time of year again. My children are growing up thinking it’s perfectly normal to find jugs of epoxy in the oven.
Yep, I keep my epoxy in the corner of the kitchen away from the counters and food. Take it out when I need it!
Post by Jimbob »
Is that oven set to 254 degrees? :lol:
DavO
Post by DavO »
This is hilarious. I too keep the epoxy in the house, it's nice to hear that I am normal. Well, maybe not "normal," rather I should say consistent with others. I'm going with the [flawed] presumption that I'm not crazy if there are other people doing the same thing.
I've been known to keep it next to the water heater.
Putting new belts on the engine and the alternator casting snapped when I tightened the belt. It was probably due for a new alternator anyway.
One school of wisdom would say replace both water pumps now while it’s easy to access but I have a strict policy of not fixing stuff that ain’t broke.
You will probably have the engine in and out several times during the build. Just check the clearances at that time and decide if you need to replace things.
Bill,
Gosh, I hope it doesn’t go in and out any more, Its all locked down and aligned. My technique is building around the mounted engine instead making the engine fit in a space.
Moving forward,
https://youtu.be/2WIaMXEBY9w
Got the alternator fixed and ran some non ethanol gas through the carb for the winter.
Charging nicely at idle
That starts nice and easy.
Under water viewing ports installed today. I sure drill a lot of holes in the bottom of this boat. The tape measure just happened to be laying there, no precision to where the holes were drilled. I used the TLAR method.
