Tom's Tahoe
Aussie
Re: Tom's Tahoe
Post by Aussie »
Tom,
If you like i can give you some measurements that have worked for me but only for the tried and tested 70mm pleat witdth. (Seam loss etc).
Jamie
Re: Tom's Tahoe
Post by DrBryanJ »
I plan on doing my own upholstery as well. I have been watching youtube videos by Cechaflo. Lots of good instruction on making pleats.
Re: Tom's Tahoe
Thanks Jamie, that would be a help.
I hadn't seen any Cechaflo videos. I check out a few, amazing work. I'll be ready for those videos someday. Right now I'm just trying to protect my digits from that pointing thing that goes up and down so fast. Looking at the manual, the pointing thing might be a needle, not sure. :lol: :lol:
Re: Tom's Tahoe
The forward sole is in. The Meranti on the left and Okoume on the right will have a vinyl or carpet covering. The 12" wide area above the keel will be used for storage and will be made after the seats have been figured out. Tom
Re: Tom's Tahoe
Nice job! Not easy to fit those sole panels.
steves
Re: Tom's Tahoe
Post by steves »
those sole panels are lovely! I used plywood and will cover them with something. Not sure what yet.
I do remember those may have taken and entire weekend to put in!
Re: Tom's Tahoe
The sole panels can chew up a clock for sure, cope to fit the frames and then relieve the underside for battens and the curve of the hull. I still need to add reinforcements along the outside edge to stiffen the panels. If I was doing it again I would use 3/4" plywood for stiffness rather than the spec'd 1/2".
The dash template is almost done. This is version three. The gauge holes are a little too close together and no switch holes, but close enough to let me move forward with the sub deck.
Re: Tom's Tahoe
This is the final version of the dash, adjusting holes and adding switches. I made a bezel diameter hole for the ignition switch, not helpful. :oops:
Re: Tom's Tahoe
Very cool, reminds me of a 63-67 vette dash
Re: Tom's Tahoe
Hercdrvr wrote:
Sat Oct 05, 2019 3:29 pm
Thanks Matt, that's the inspiration. I'm planning to wrap/crash pad the edge of the "eye brow". Tom
Re: Tom's Tahoe
What's your plan for the rest of the deck? Are you doing a "utility" layout?
Dash will be as unique as the transom.
Re: Tom's Tahoe
Jim,
I'm headed toward a utility...except I have the exhaust coming out the sides, so it won't be traditional.
Re: Tom's Tahoe
Now those cowls are interesting! Very nice.
Re: Tom's Tahoe
Thanks Matt.
I had a piece of Santos Mahogany left over from another project. Now its a dash!
Santos has a spicy smell and makes the shop smell better. :D :D
I have been thinking about a "glove box" under the port cowl. What do you think?
Re: Tom's Tahoe
Glove box would look nice. I usually screw a shiny grab handle on the passenger side of the dash, mostly because at this stage of the build I’m closing in on the finish line and a glove box would take too long.
