And a progress photo.
About 1200# of floatation foam is in. I'll tuck in a little more just before the ceiling panels are set for the last time.
The rough wiring is done, LEDs run behind the carling for "mood lighting".
I decided to rap the edge of the cowling with foam backed fabric, done.
Both carlings are wrapped too. There is a little more padding, almost crash pads but not quite. There is a bit of trim on the bottom edge, one side done, one side not. I'll need to install the trim on the other side before I can set the dash.
A temporary mounting of the dash exposed some wire location conflicts. Gotta mount the dash to bleed the steering. Gotta bleed the steering before putting the fuel tank and so on.
All the ceiling panels have been wrapped. I used finish washed to hold the panels. Some of the washers cut the fabric so I'll give upholstery buttons a try.
I decided to carpet, almost done, two pieces are waiting for final placement of ceiling panels.
Two pieces to go and the rub rails will be done.
I order the trailer in late June with a promised three or four week build schedule. Still waiting (not that it is keeping me out of the water)
