Tahoe 23 prop size?
Brad Tucker
Tahoe 23 prop size?
Post by Brad Tucker »
I am trying to figure out which prop size I need for my Tahoe23. I would love to have at least a good starting point, then fine tune from there If needed. The current information I know is this:
Set up for 13" prop
351V8 rated at 240 hp
WOT RPM 4400
cruise RPM 3600
Weight 3500 lbs (educated guess, AKA SWAG)
Weight is a guess, based on Butch's Tahoe. I subtracted from his weight the difference between BBChevy and SB Ford, approximate weight of the stretch, and approximate weight of an extra ply layer.
I don't expect to be pulling skiers anytime soon. I appreciate any information anyone with the knowledge could provide. It would at least get me in the ballpark. My best current plan is to start with a 13x13 and go from there.
Re: Tahoe 23 prop size?
Brad
What is you gear ratio? Then I'll take a stab at it.
Brad Tucker
1:1. Sorry, I meant to mention that.
Mr Hot Rod
Post by Mr Hot Rod »
Brad,
Here's an Excel spreadsheet which might be useful. It will provide you with SHP required to maintain a given speed :
Input Specs :
  • 351V8
  • 240 hp
  • WOT RPM 4400
  • Cruise RPM 3600
  • Gear Ratio : 1:1
  • Weight 3500 lbs (educated guess)
What's missing is desired maximum speed (MPH).
We've specified the following parameters : MPH = 50 MPH, Displacement of 3200 lbs. and 3500 lbs.
Analysis :
  • The spreadsheet calculates two different engines with four gear ratios :
    12% overdrive, 1:1 direct drive, 1.25:1 and 1.50:1 reduction ratios.
  • At the bottom of the spreadsheet, you'll find notes about the Optimum Pitch Formula.
  • Red cells indicate props with ideal PD (Pitch/Diameter) Ratios.
  • Image
    Click the image to see the PDF document.
Recommended Ratios and 3 Blade Propellers :
  • Required speed 50 MPH, weight 3200 lbs., 240 HP @ 4400 RPM : .88 / 11x15, 1.00 / 12x17
  • Required speed 50 MPH, weight 3500 lbs., 240 HP @ 4400 RPM : .88 / 11x15, 1.00 / 12x17
Feel free to download the spreadsheet and modify it to suit your needs :
More info and calculators on our website's Propeller Page.
Hope this helps !
________________________________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
Glen-L Hot Rod build thread
Glen-L Boat Video Directory
Brad Tucker
Thanks Paul! So, according to your work, a 12×17 should push a 3500lb boat 45mph at WOT with 238hp. Am I reading that correctly?
Mr Hot Rod
That's correct. You'd have to add 36 HP to go 50 MPH.
Download the spreadsheet and specify Required maximum speed = 45 MPH.
This is a great tool for determining gearing, SHP and Speed. Of course this would require an engine in top mechanical condition (sufficient HP and Torque) to attain the required speed.
Paul Kane
Chelsea, Quebec
Brad
Paul is definitely the man. I think 12x17 is damn close. I don't think at your RPMs you need to go larger than a 12" prop. I run about 115 HP with a 13x16 prop. at 3100 prop RPM at can run 38 Mph.
Brad Tucker
Bill and Paul, thank you very much for the information. Going about it like a blind hog hunting acorns wasn't going to be fun.
Brad Tucker
And, a 12x17 isn't just a click away on the net. Acme has a 12.25x15.25 in a 1" bore, then they go to 13"s.
Mr Hot Rod
We never said that this process was going to be easy !
OJ Legend 3-blade sizes
  • Part Number / Specs :
    • 1008 / 12X15 LC 1"
      1010 / 12X15 RC 1"
      1012 / 12X16 LC 1"
You can also have a 15 or 16 pitch propeller repitched, or have a larger diameter 17 pitch propeller cut down to 12".
The Glen-L Inboard Hardware Catalog lists a prop that is very close to what you need : ____________________
Paul Kane
Chelsea, Quebec
Brad Tucker
You could have warned me! :lol: I knew about the GL one, and it is close. Maybe close enough. There is an inboard specialty close to me who will let you run a prop for 30 days and swap it out for another if not satisfied. If I went up in diameter and down in pitch, is there a such thing an equivalent prop? I can go to 13". Or, from 3 blades to 4? Or both?
Brad
I have a 12x17 LH 1" that I can sell you. New bronze. I'm happy with the 13x16 I have. It is down at Gulf Shores.
Mr Hot Rod
Brad,
Download the Diameter-HP-RPM Formula spreadsheet from our website and input your specs : More light reading from our website :
Paul Kane
Chelsea, Quebec
Brad Tucker
I appreciate all the help. Paul, your spreadsheets are great. After thinking most of the night, I realized I had to add in weight for people and fuel. I used the spreadsheets to dial in numbers until the available HP most closely matched needed HP. If I did it correctly, it appears that a 12x15 or 12x14 will put me there, and give me 39-41 mph without going over the max HP available. 4000 lbs and 4600 lbs respectively. Unless I missed something. That's highly likely with me.
Brad
Did you add the Ice Chest? :lol:
