Tahoe 23 prop size?
Re: Tahoe 23 prop size?
Brad Tucker wrote:After running the 13x12, I found that it would allow the engine to exceed the max WOT of 4400rpm. I'm not sure by how much, because I didn't allow it to happen. I had more throttle left, and was running mid-upper 30's mph at 4400 rpm. Test run 2 was with an Acme 13x13. Max attainable rpm was 4200 with 42mph. Interestingly, I was getting around 28mph at 2500 rpm. The Speedo is a Faria GPS Speedo and I did not cross check it with any other GPS device. I'm thinking I will keep her propped with the 13x13 Acme, although the 13x12.625 they offer may be the perfect prop. Engine is a mid 90's PCM 351 rated at 240hp with very few hours.
Hi,
Sounds like you got a 42mph boat, pretty good.
You mentioned 2 different Acme props, what was their stated cupping for each prop?
Brad Tucker
Post by Brad Tucker »
.080" for both.
Brad Tucker
Rich, I thought so, as well. The 12 made it jump out of the hole. I noticed with the 13 I get a little tail wag it seems during holeshot if I throttle up hard. I don't know if that is normal, but I don't plan on doing that often. Midrange acceleration is pretty impressive to me.
