Tahoe 23 project, Norway
Toivo
Re: Tahoe 23 project, Norway
Post by Toivo » Mon Aug 14, 2017 1:13 am
Rich Coey wrote:Speaking of Van Dam boats,
A member of our ACBS chapter has three. Check out those, and some other great boats.
https://www.boatiquewines.com/about/boats/
Rich
Wow :o
Building the Tahoe 23' viewtopic.php?f=15&t=31598
Toivo
Post by Toivo » Mon Aug 14, 2017 1:56 pm
Working on where to by the plywood today. Man, AA marine plywood is not cheap! But I think it's a good investment to go for the best. At least for the hull. The sea here tend to be pretty choppy. And I'll imagine the more experience plywood is easier to work with, i.e. less frustration and more fun.
Toivo
Post by Toivo » Thu Aug 17, 2017 12:26 pm
In my search for boat related content, I stumbled over this video: https://www.youtube.com/watch?v=JXKRy33jHUw
About 1:30 in, you'll see he opens the hatch for the motor. I noticed the the latch and the hinges. The latch is like a door handle on an aston martin :D And the hinges are covered from spray water. Is there a place that sell these new?
Toivo
Post by Toivo » Tue Aug 22, 2017 3:40 pm
I have another dumb question. Can I instead of using 4mm plywood for the hull, use 4mm pine cut into 4" strips? Any strength issues?
Post by PeterG » Wed Aug 23, 2017 7:17 am
You can do that. It's the original way to do cold molded construction, and I believe the Van Dam boats are built that way. Typically, marine plywood is more convenient and lower cost per square foot but it's structurally acceptable to use thin boards. The installation is the same.
Post by Bill Edmundson » Wed Aug 23, 2017 8:12 am
Toivo
I don't know about the handle. I think Jenko made some of those hinges.
Post by TomB » Wed Aug 23, 2017 12:22 pm
PeteG is correct about Van Dam using solid lumber to cold mold. They use alaskan yellow cedar for the inside layer and then switch to marine plywood for the intermediate layers. It makes for a beautiful interior.
I agree the hardware looks great. Wonder where it came from.
Toivo
Post by Toivo » Fri Aug 25, 2017 6:16 am
Bill Edmundson wrote:Toivo
It seems that this type of hinges is called billet hinges.
TomB wrote:PeteG is correct about Van Dam using solid lumber to cold mold. They use alaskan yellow cedar for the inside layer and then switch to marine plywood for the intermediate layers. It makes for a beautiful interior.
Maybe a combination is the solution :)
Does someone have information of the total weight of the boat, and weight distribution?
Toivo
Post by Toivo » Fri Aug 25, 2017 8:48 am
I went through van dams gallery, and holy crap this dash!
Toivo
Post by Toivo » Fri Aug 25, 2017 1:26 pm
Is that dash made out of glass fiber with veneer? Or is it possible to even get these shapes with a wooden frame?
gap998
Post by gap998 » Fri Sep 01, 2017 2:58 pm
I'm sure I've seen other construction pictures of this dash, showing it being constructed out of "stepped" wood laminates, like Lego, before being sanded to shape. Van Dam really continue wooden boat building into the 21st century. I love the classic shapes but modern designs like this show how you don't need to be plastic to be cutting edge!
Gary
Toivo
Post by Toivo » Sun Sep 03, 2017 1:50 am
gap998 wrote:I'm sure I've seen other construction pictures of this dash, showing it being constructed out of "stepped" wood laminates, like Lego, before being sanded to shape. Van Dam really continue wooden boat building into the 21st century. I love the classic shapes but modern designs like this show how you don't need to be plastic to be cutting edge!
Indeed they are cutting edge. And it seems they have made a good brand. Do you remember where you saw those pictures?
Toivo
Post by Toivo » Sun Sep 03, 2017 2:46 am
I have a question about screws. Is it okay to use stainless steel instead of silicon bronze under the waterline?
And I see some people use screews for the plywood in addition to epoxy. Is that necessary?
Post by JimmY » Sun Sep 03, 2017 5:28 am
My understanding is that Stainless Steel will corrode if it is fully encapsulated, so you want Bronze wherever this will be the case. Also, the screws are mostly for holding the wood together while the epoxy sets up, but many like the added insurance that screws offer.
Post by TomB » Sun Sep 03, 2017 8:03 am
Fasteners are a big investment. I am using SB because of corrosion concerns, with the exception of the carriage bolts between frames and motor stringers (a significant savings and easily inspected).
So far, I have been able to find five screws with router bit and saw. In that respect, I much prefer SB.
