Double layer ply vs single...
Conrad
Post by Conrad » Mon Oct 08, 2018 11:05 am
So the bottom of the flyer asks for 2 layers of 1/4 instead of 1 of 1/2. I know the question has been asked of some, but to get a fresh opinion, which is better? On the one hand, there are no single points of weakness in the hull as 1/4 is offset from the second, but on the other hand, there is no way to make sure there are no air gaps between the 2 layers of 1/4. Thoughts?
Keep your lines tight!
Conrad
Re: Double layer ply vs single...
Post by Bill Edmundson » Mon Oct 08, 2018 11:28 am
The 1/2" will be very difficult to bend.
Conrad
Post by Conrad » Mon Oct 08, 2018 11:56 am
Bill Edmundson wrote:The 1/2" will be very difficult to bend.
Like the last flyers, would be half to the bend and then 1/4.
Conrad
Post by Bill Edmundson » Mon Oct 08, 2018 1:31 pm
1/2" is 8 times harder to bend than 1/4".
Post by PeterG » Mon Oct 08, 2018 7:10 pm
To minimize the chance for voids between the layers of 1/4" plywood, you could try vacuum bagging the second layer on. Have a look at Bob Perkins' Biscayne 22 project: https://bperkins.wordpress.com/2017/11/ ... ayne-22-2/
You would pre-fit the second layer dry, then epoxy it in place, apply the vacuum bag materials and apply the vacuum. 14.7 pounds per square inches is a lot of force and makes sure you're getting a full bond, with excess squeezed out the edges.
Bob Perkins
Post by Bob Perkins » Tue Oct 09, 2018 7:11 am
Nice to see my site is still getting used.
and agreed - If you want to be certain to have no voids - vacuum is the best way to do it..
Vacuum is the perfect clamp - 2000+ pounds of clamping pressure per square foot in the exact shape of your boat..
AND - if there is a void potential - the vacuum pulls out the air and glue is all that is left to fill it.
When I was laminating my boat - there was nearly nothing on the topic (for home use).. I'm certain its pretty well documented out there now..
Good luck!
Regards,
Bob Perkins
All the Fun Stuff
Post by Hercdrvr » Thu Oct 11, 2018 6:12 pm
How much are you going to weaken 1/2” plywood trying to bend it into shape? I don’t know much about the flats flyer shape but 1/2” ply isn’t going to yield much. 1/4 on top of 1/4 held with Poxygrip and some screws and it won’t be coming apart in our lifetime.
Bob Perkins
Post by Bob Perkins » Thu Oct 11, 2018 8:03 pm
I looked at the picture of the boat..
The bottom is relatively flat - however - there is twist..
Twisting 1/2" plywood is going to be a pain... its going to put up a fight.. pulling on frames, etc as you get it into position..
just a thought.
Regards,
Bob Perkins
All the Fun Stuff
