Motor stringers
admjake
Motor stringers
Post by admjake » Tue Jan 15, 2019 12:53 pm
I am ready to purchase Sapele boards for the motor stingers to be used on my 19-20' Barrelback.
Full-length boards are available but at a significant surcharge, is there a benefit that justifies the increased cost?
Re: Motor stringers
Post by Bill Edmundson » Tue Jan 15, 2019 1:18 pm
admjake
My stringers are laminated 1x's. Each one also is spliced. The splices are not under the engine.
Re: Motor stringers
Post by 283 » Tue Jan 15, 2019 3:45 pm
Laminated is often stronger and straighter than solid lumber.
Mike
Re: Motor stringers
Post by Roberta » Tue Jan 15, 2019 4:50 pm
I used four quarter white oak sandwiched between 9mm Okoume plywood ((both sides) nailed and glued. Rock solid stable and straight as an arrow. You could do this with Sapele.
Re: Motor stringers
Post by Jimbob » Tue Jan 15, 2019 5:22 pm
I made my motor stringers by laminating two sapele boards together with scarf joints away from where the engine would be. I checked for straightness during the lamination process. Screws were used in the gluing process. They came out perfectly straight. (the lamination process will result in straighter stringers than one solid piece) Pics below.
Cutting the scarf joint
The scarf jig
The scarf jig
motor stringer glue up
Re: Motor stringers
Post by Jimbob » Tue Jan 15, 2019 5:28 pm
After the motor stringers were both glued up. I clamped them together to cut the notches for the frames. I did them both at the same time to insure that the frames would be in alignment.
Notches in the motor stringers
Cut notch for a frame
Cutting the notches both stringers clamped together for the cut
Bob Perkins
Re: Motor stringers
Post by Bob Perkins » Wed Jan 23, 2019 8:10 am
Agreed - laminate and scarf - stronger and more stable.. with the benefit of less cost.
Regards,
Bob Perkins
All the Fun Stuff
