Bob Brown’s Belle
Re: Bob Brown’s Belle
Post by neel thompson »
Thanks Bob.... I think I get it, but I've gotta quickly get to my "Thinking Chair" ….. I'm having a little trouble figuring out the come along, how it's attached, and what it is attached to. Also not clear on the strap shortening process and how it failed....
Ingenious rigging Bob. Congratulations on the flip and fine workmanship.
I hung my boat from the ceiling with straps and rope. Like you, I was surprised by the change in rope length during the flip. The problem can be visualized in your photo of the boat suspended before the flip, the length of strap is two times the vertical run almost to the floor plus the length of the strap across the beam. As the boat is turned the beam length of strap becomes the heigh of the boat strap...maybe four or five feet shorter.
BobBrown55
Post by BobBrown55 »
TomB wrote:
Mon Oct 28, 2019 11:14 am
Thanks, Tom. You're exactly right on the issue with the length of the straps. Wish I'd thought more about that before. It wouldn't have been that hard to even model it with a piece of wood shaped with the Belle's profile and a piece of string. But, the wooden structure was the key and we were able to overcome the issue in a few minutes, so all that was lost was style points.
Building the Belle Isle ... slowly.
I had trouble with the lengths too, on the Tahoe.
BobBrown55
It's procurement day (again). Getting parts for the water intake. I think I'm going to get this fancy filter. How are these mounted? I can't tell from the picture (see below). Should I drill a hole in that tab and bolt it to something?
Ah, wait. On the Jamestown Distributors website, there's this in response to a question: The strainer has a mounting bracket that screws or bolts to a vertical flat member such as a bulkhead, etc. The strainer attaches to the mounting bracket and is fastened in place with a nylon wire tie.
Anyone have any good pictures of how that looks after installation?
Post by Jimbob »
Hi Bob,
I have the same fancy filter. It comes with a bronze piece that the filter hangs on. I attached that bronze piece to a wood bracket that is attached to the motor stringer. Downwind Marine out of San Diego (you can find them online) has a good selection of bronze fittings for the hose connections.
Pics below of my setup
BobBrown55
Hi Jim,
Thanks for the photos. I see the bracket. Looks simple. (Though making it look as nice as you did might not be so simple.)
That helps a lot. I appreciate it!
This stuff is expensive!
Thanks again,
BobBrown55
Jim,
One more comment. Looks like Jamestown is tough to beat on price. They have the filter for $265. Downwind is at $335 and Fawcett (where I found good prices on silicon bronze carriage bolts) is at $350.
BobBrown55
Jimbob wrote:
Wed Oct 30, 2019 10:08 am
Hi Bob,
Jim, a question on your setup. What diameter connections do you have coming out of the seawater pickup? Mine is 1-1/2", but the 90 degree hose barb I'm finding to come out of that has a connection for 1-3/4" hose, which I can't find.
Post by Jimbob »
Hi Bob,
I think I got mine from wholesale marine.com . Just checked, their 1 1/2" filter is 234.43.
I got some of the harder to find fittings from downwind marine. They probably have what you are looking for.
If I remember correctly my system is 1 1/2" throughout.
Will check my invoices tonight when I get home and let you know what I got, and where.
here's a few other suppliers I have used.
defender marine
go2marine
wholesale marine (one of my favorites)
iboats.com
fisheriessupply.com
don't forget glen-l
Post by Jimbob »
Ok Bob here you go.
the fittings are all 1 1/4". Bought the 1 1/4" filter from go2marine.com for 172.24. Also bought the fittings from them. Pic of the mounting bracket below.
BobBrown55
Thanks, Jim. That’s all very helpful, especially the photo of the bracket and your installation.
Thank you!
BobBrown55
Epoxy issues ...
I’m working to seal the interior and having issues with the epoxy.
I applied 2 coats of CPES and it has dried for several days. I’m pretty sure it’s dry as it’s not sticky at all and, as mentioned, it has been several days since the application was finished.
But the epoxy application is not going well. Immediately after application, it looks nice and smooth, but it soon develops a weird blotchy appearance. See the photo.
I’ve tried both MAS epoxy (which I used successfully for the bottom and sides) and West Systems, which I used to glue the frames and for the cold molding.
Both seem to be within spec for current temps. It has been consistently above 50 degrees in my garage / shop. It is humid (seems like 110% humidity today, but actually at 86% right now), but it Is always humid here in Oregon.
I’ve kept the epoxy in the house for a couple of weeks so it would be a bit warmer than the garage and hopefully have better viscosity.
I’ve tried each of the following on different sections:
1. Warm the wood with a heat gun (this also dries it a bit).
2. Sand before applying the epoxy (and vacuum up the dust).
3. Clean the surface with Naptha thinner.
None of this prep makes any difference.
I was concerned that the West Systems epoxy had been here for a while (like 2+ years), but their website says that shouldn’t be an issue. And, the good news is that the epoxy cures to a solid finish (both brands).
A second coat seems to fill the ‘holes’ pretty well, but it sure seems weird that I’m getting this weird result.
The only other thing I can think to try is to use epoxy that’s at the same temp as the garage / boat. Maybe the sudden cooling (from 70 to 55) is causing this?
What am I missing? What would cause this?
This is just a suggestion Bob..... I use West System and have found if you put on very thin coats later in the day as the temperature starts to drop, the results are much better. Not sure but, from your picture, it appears you are putting on very thick coats. Even though it doesn't look like you want, it certainly appears to be encapsulated.
Post by DrBryanJ »
I have never used cpes before, but does it get an amine blush? That is what it looks like. The surface needs to be cleaned with warm soapy water.
