Rub rails
Re: Rub rails
Brian wrote:
Thu Dec 12, 2019 10:04 am
Thanks, Jim. So you are saying to pre-bend the bow section rather than muscle it around?
Yes, It should be enough to bend a simple curve into the rail. If you put paper on the side of the hull and draw a line at the deck, when you lay the paper flat you will see it is a simple curve. Bend it to this curve and when you apply it you should be able to twist it into position.
I tried to bend my rub rail as I screwed it down, but it tended to bend and kink at each screw hole.
Re: Rub rails
Post by Jimbob »
I think that the moldings underneath my rub rails probably helped in preventing kinks or bends at the screw holes.
I ended up using 1" screws on the rub rails.
Aussie
Re: Rub rails
Post by Aussie »
My rubrails were only 3/4 so quite easy to bend around the bow and twist where needed.
Jamie
Re: Rub rails
I just went with wood rub rails, but then, I have a painted hull topsides. The rub rails are the same wood as the inside carling, so that helps the wood matching. I had thought about the stainless rail caps, but never feel the need now some 10 years later.
In the Sapele wood, can you see how the bronze boat screws seem to disappear in the wood??
Rich Coey
Re: Rub rails
Post by Rich Coey »
Rub Rails? Screws? what screws? I don't see any screws.
Re: Rub rails
Nice picture of the twins.
Re: Rub rails
I used 3/16"x1" 6061-T6 on the Bartender. Pretty easy to work with. 6061-T6 is a structural grade aluminum. It doesn't pit in a salt environment. It may not polish well.
https://www.metalsdepot.com/aluminum-pr ... m-flat-bar
Brian
Re: Rub rails
Post by Brian »
Well, I've resorted to heat. No way that rail is going to bend and twist cold with screws. So it's back and forth between the shop and boat for fitting. I'm using MAPP gas, which gets about 2-3" red hot at a time and following that along a foot or so, using a Jorgenson clamp to twist. Even at that, it isn't easy and the twist/bend is hard to estimate. Of course, the SS is all discolored now, but I've confirmed on a scrap piece that it will buff out. Been working on one rail for 3 days. Not sure if I'm getting there or not.
Re: Rub rails
Brian can you post some pictures?
Brian
Re: Rub rails
Post by Brian »
I wish I could post pics, but last time I went through the process I ended up asking Gayle to do it for me. Not sure why I'm such a dunce at it, or why you can't just drag and drop into this Reply box.
The status now is we have one side on, but there is still a section that is away from the hull at the bottom. Probably needs another heat up and a twist. With MAPP gas, I can only get about 2-3" cherry red at a time, while my friend uses a Jorgenson to twist. The rebound is considerable, so it's really driving blind, trial and error. The last couple of feet to the bow is a reverse twist, just to make it real interesting! The bow, of course, also slopes forward for drainage, so the forward 4-6' of the rail also needs to be bent downward.
If there are any metalworkers out there, maybe some help? I'm wondering if repeated heating is doing anything to the material. It never gets easy, so I'm sure if I had a huge MAPP gas source and head, it would be easier. Also maybe more of a risk of deforming.
Re: Rub rails
Brian,
I'd like to see photos too. To add photos, go to the attachments tab below the reply box, click on the add file button and navigate to your jpeg photo (pdf doesn't work), once you get the green check mark at the right click on the place inline button and you're done. Hope you'll give it another try.
Brian
Re: Rub rails
Post by Brian »
Test
Re: Rub rails
A+ congrats
Brian
Re: Rub rails
Post by Brian »
It works! Thanks!
The discoloration buffs out, so no worries there. As you can see in the underside shot, we still have about 1/2" to go there, which is more twist. The alignment is not perfect yet. I will drill out the fitting screw holes and epoxy hardwood dowels in them to make the final holes.
Brian
Re: Rub rails
Post by Brian »
Oh, and that's just a quick coat of Interlux sealer on the deck and bare epoxy on the sides.
