To cutwater... Or not to cutwater... That is the question
Bluesman
Post by Bluesman »
Tahoe - 21' - Period correct where possible
Pardon me for channeling William but I've seen this go both ways.
1) I like the look of the stainless on the bow
2) I believe it protects the point of the bow
3) I'd like it to follow down below the water line But I'm concerned about the "Glen-L Step" at the Chine.
4) I'm concerned about getting the fit right.
Pros & Cons? You're expert opinions are appreciated...
Re: To cutwater... Or not to cutwater... That is the question
I think the juncture of the stem and chine should be faired smoothly providing a flat surface for the cut water.
Bluesman
Post by Bluesman »
That is my thought and I'm at that stage right now. Still, just wondering about getting a nice fit..
I wish I could weld stainless. :?
Yup, the first 2 or 3 inches out from the leading edge of the stem will be very vertical from the bottom planking to the side planking. Fairing that prior to planking will give you a nice transition for the cut water.
Ted,
I wove the planking layers at the bow so there is a smooth transition for the first 4" at the bow (2 3/4" is the minimum width for one cutwater guy). If you have a chine line to the stem after the sub-layers you could fair it smooth and then cover with the veneer.
Two other vintage approaches to consider -
Some brought bottom paint above the waterline as the chine left the water. If you did that you could glass the bottom and rely on it to protect the edge near the water.
For a while, ChrisCraft left a flat surface on the leading edge of the stem and then used a narrow bit of plated brass to cover it. Using a narrow rub rail would give the same look.
Two other cutwater thoughts before veneer planking.
The cutwater guys don't seem to like a concave curve on the leading edge of the stem between the sheer and the chine. I have about a 1/4" and one guy grumbled about it.
How will you hide the top edge of the cutwater? Again referring back to some of the ChrisCrafts, the sheer was left an 1/8" proud of the hull at the stem and then faired back to 0" proud in the first 18" so the cutwater stopped at the bottom of the sheer and they could do what they wanted with rub rails, etc. (invisible unless you're looking for it).
Bluesman
Post by Bluesman »
My plan is to overhang the deck at the bow and bring the cutwater up under that. I'll use SS rub rails mating up on each side.
And some kind of a bow handle / cleat, etc... I'll know it when I find it I think!
I'm fond of the fairlead approach to bow caps, something like this Riva.
Andy Garrett
Post by Andy Garrett »
"Glen-L step"
Never heard that one before.
Is this suggesting that Glen-L craft do not have a smooth transition at the chine near the stem? I wasn't aware they had a reputation for this characteristic.
Andy Garrett
Bluesman
Post by Bluesman »
That's just me being me.... Thinking of the Hillary Step.
There are 3 layers on the bottom and 2 on the sides, thus where they meet at the chine in the forward frames up to the bow there is a noticeable step, ledge, hump, whatever you want to call it. Fairing is the answer, but don't go too far with it.
Bluesman wrote:
Sat Jan 18, 2020 8:39 pm
A lot of builders leave the step there, and that is where the chine spray rail goes.....
Bluesman
Post by Bluesman »
Yes, I will be installing the spray rail and I have faired off the step at the stem about 3 inches back on both sides.
Post by Jimbob »
I got my cutwater from cutwaters by mike. I had a hump at the chine at the transposition point on my barrelback. Mike said that the cutwaters are somewhat flexible, but you don't want the "hump" to be too pronounced at the chine. Mine was pretty noticeable, so I faired the plywood down before putting on the final mahogany planking. Mike sent me a pattern from an original barrelback which I used to determine how far to go below the waterline, and the the width at different points. You might be able to find a reproduction fairleader that would fit your boat. Make sure you get a tracing of the fairleader to see if it will fit your boat. The reproduction that I got, didn't match the angles of my breasthook, so I got a larger fairleader and had it modified to match a pattern of my bow. After the modification was made, I had it plated. I still have my original fairleader. I would be glad to send you a tracing of it so you could see if it would fit on your boat. I got my fairleaders from california classic boats.
Another shot of the fairleader
Here you can see it doesn't fit. Original boats were more pointed at the bow.
Fairleader lip goes over the top of the cutwater. Width of the cutwater varies like the original boats.
Bluesman
Post by Bluesman »
Thanks and good info. I'll let you know about the fairleader once I get to that point. Ways to go still...
