Barrelback in san antonio
Re: Barrelback in san antonio
Post by Jimbob »
Here are pics of the drain holes. I used a router bit normally used for carving bowls. It is 1 1/4" wide by 5/8" deep. It makes a nice smooth cut so that nothing gets stuck in the drain. Each frame gets drains so that water can flow to the rear of the boat. Note the cross drains in the transom so that everything drains into one outlet.
The bearing prevents you from cutting into the battens by mistake.
The transom area with cross drains
Bow area
Bow area
Joerpilot
Post by Joerpilot »
Thanks for the pictures. Where does the water go after it passes throu the transom?
Joerpilot
Post by Joerpilot »
Thanks Neel.
Post by Hercdrvr »
Hi Joe,
25 sheets of plywood will be perfect, I ordered 27 and had a few left over.
